Results 1 to 13 of 13
    Jul 2017
    Default Dashboard & immo programmer / tool cheap and good
    Hello
    Im now in motorcycle business the Piaggio Gilera Vespa Group.
    for the immo clone or found there ist the ScooterWorkshop.
    but I need also program the dash.
    do someone know a good and cheap tool?
    because I have at this moment not to much money.
    Or can I program the EEPROM from the dash with only a Laptop and kabel+program or do I need a hardware like a driver ?
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Buy UPA 1.3 USB programmer very cheap and good tool
  3. The Following 3 Users Say Thank You to jomberykaso For This Useful Post:
    autodiagdoctor (18th April, 2018), kur715 (31st August, 2022), Lazkaris (7th July, 2017)
    Jul 2017
    Thanks, I want to buy the upa but how can I know wich eeproms the wil support?
    And can I run immo software with the UPA and program keys ?
    Piaggio uses eeproms like this;
    93c56
    93c66
    93s56
    24c02
    U.S.A
    upa usb support all the eeproms that you described,but it's just a memory programmer,will not program keys or disable immo unless you know the immo or key bytes location in the dump
  6. The Following User Says Thank You to maumaumau For This Useful Post:
    Jul 2017
    Thanks for youre info, My last quesion before i order this upa 1.3
    Can do digiprog 3 clone same and more thing as upa 1.3 ?
  8. #6
    Jan 2016
    Digiprog 3 - good quality clone works quite well and does a lot of vehicles / eeprom types. Has some limitations and the software is a bit outdated now, but still a good stand alone eeprom programmer - supports a lot of vehicles and bikes and heaps of info for different makes / models on the net for them.
    UPA is PC based, a bit more advanced, but a wicked piece of hardware. Not as easy as the digiprog but works very well and is probably better for newer stuff.
    My 2c worth.
  9. #7
    Jul 2017
    Hi I bought a Digiprog3(with usb) because i can used also for cars.
    I have try to read the EEPROM 93s56 but i can't found this eeprom in digiprog3, there is 93sc56 If I read my eeprom with this settings they cannot found a chip(error message)
    I read it with the eeprom clamb, what do I wrong?
    Have some one software to change mileage on my laptop? I can pair my laptop with digiprog.
  10. #8
    clusters's Avatar
    Mar 2015
    Canada
    Your clone might not connect to your laptop because a lot of them missing the FTDI chip. (see pic) Then you need eetool, search the forum and you will find all you need.
    The eeprom clip they supply is crap, buy a better one like a genuine Pomona (yes, they clone these too) and make sure the chip legs are clean and the clip on properly (red wire to Pin 1)
    The file below will also be helpful
  11. The Following 4 Users Say Thank You to clusters For This Useful Post:
    Carlos Vicente (18th April, 2018), Dr. Zoidberg (30th November, 2017), jomberykaso (30th November, 2017), sapopt (1st December, 2017)
  12. #9
    Jul 2017
    Can Digiprog3 read eeprom 93s56 ?
  13. #10
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    buy cheap get cheap, the man gave you a great solution . UPA-S will take are of your needs now and future . the easy way is not always the right way
    Reading is fundamental, asking is easy............................
  14. #11
    Aivis3's Avatar
    Sep 2016
    Latvia
    I think same better cheapest programmer is TL866CS or TL866A. Very well working with eeproms or flashes in Engine ECU. Maybe need some adapters only.
    Not working with 95P08 (in some engine ECU). For 95P08 I using Xprog 5.55 clone.
    For Motorola MCU need other programmer, for exsample Xprog or UPA...
    If helped - "Thanks" and "Reputation" please
  15. #12
    Apr 2018
    thank you very much
  16. #13
    Tefocm's Avatar
    Sep 2013
    Planet Earth...Take me to your leader.
    Quote Originally Posted by Aivis3 View Post
    I read this as ST95040 just fine with TL866A mate...
