Results 1 to 14 of 14
    DK Veteran gtmech's Avatar
    Hell
    Default Great Wall Remote Key Programming
    Anyone know how to program the remote key (remote functions only) for a 2011 Great Wall X240? The transponder is easy but the remote part seems to be top secret.
    Tried the toyota procedure (because the key looks like a Toyota key) but i think its completely different. I know its a manual procedure but no idea how to do it, anyone tried this before? thanks for any help
    lion0304's Avatar
    Oct 2014
    Try program remote with X100. If Id46, use under Chery
    Hell
    manual procedure
    Hell
    anyone can help?
    Mar 2017
    Australia
    Hi mate, I have never tried to do one before but found this info you can try the procedure and see if it works
    1. Open the Driver's front door and insert the key into the ignition
    2. Turn the ignition key from OFF to ON 5 times, finishing with it in the ON position.
    3. The indicators will now flash once to indicate programming mode is active
    4. Press either the lock or the unlock button on the remote control
  6. The Following 6 Users Say Thank You to Hugh91 For This Useful Post:
    gtmech (19th July, 2017), KevinXTR (30th September, 2017), khalcdi (18th July, 2017), lion0304 (20th July, 2017), mossa19 (23rd August, 2018), salmanovo (14th April, 2022)
    dyzio's Avatar
    Jan 2014
    Racek
    hi u can try this
    1. To store new keys into the central locking remote controller proceed as follows :
    2. Turn the ignition key ON/OFF five times and stop at the ON position.
    3. Indicator lights will flash one time.
    4. Wait 5 to 6 seconds.
    5. Indicator lights will flash one time.
    6. Turn key ON/OFF three times.
    7. Indicator lights flash one time.
    8. Press the remote control button on each remote control key to be programmed, one after the other.
    9. After 10 seconds of no actions the system will close.
    Be yourself; everyone else is already taken.
  8. The Following 2 Users Say Thank You to dyzio For This Useful Post:
    gtmech (19th July, 2017), lion0304 (20th July, 2017)
  9. #7
    Hell
    thanks guys, will try those
  10. #8
    Apr 2016
    Quote Originally Posted by Hugh91 View Post
    WORKS FINE FOR GREATWALL WINGLE, REMOTE SIMILAR MODEL OF TOYOTA 2 BUTTONS
  11. The Following User Says Thank You to SMARTKEYAUTOS For This Useful Post:
    lion0304 (22nd August, 2018)
  12. #9
    Nov 2018
    Quote Originally Posted by SMARTKEYAUTOS View Post
    Where did you buy the replacement remote from?
    I have been looking online and no one seems to sell replacement remotes for Great Wall cars.
    I have a 2012 Diesel Great Wall Ute V200.
    Thanks in advance
  13. #10
    Sep 2018
    Quote Originally Posted by Jimmdee View Post
    Thanks in advance
    I've just bought " Alarm Transmitter and Blank key from LDV Lansvale for $110. You just pull the Transponder of your non remote key and transfer it into new Blank key with Transmitter and get the key cut than program it in the Ignition.
  14. #11
    Sep 2018
    Quote Originally Posted by dyzio View Post
    hi u can try this
    Tried the other procedures. Thus , did not work. YOUR PROCEDURE DID WORK. THANK YOU KINDLY!
  15. #12
    Sep 2018
  16. #13
    Jan 2017
    USA ����
    so its an isuzu body
    with chinese/bosch/SAIC/mitsubishi engines
    with toyota parts thrown in for fun
    that must be fun
  17. #14
    Nov 2015
    Europe
    Default GW Steed correct procedure
    Good for GW Steed
