Results 1 to 12 of 12
    May 2017
    Default VW GOLF 3 BOSCH MOTRONIC MP9.0 IMMO OFF
    Could somebody make immo off please?
    VW Golf mk3 1996 1.4l Aex Bosch Motronic MP9.0 0261 203 613/614
    Eeprom B58258 24C02
    Eprom B58400 TI 87C510 DIL 28
    Gdansk Poland
    Hi. Post dump from immobox hc05
  3. The Following User Says Thank You to adiagnostyka For This Useful Post:
    bh01 (18th July, 2017)
    May 2017
    What is immobox hc05?
    I haven't got it.
    South Africa
    Just reprogram 24c02 ,pass free,regards
    Do what you can with what you have .
  6. The Following 3 Users Say Thank You to ecufix For This Useful Post:
    bh01 (16th July, 2017), LuisBand (6th July, 2018), vegi32 (28th August, 2017)
    May 2017
    Thank you, man!
    I will try it and tell you if it works.
  8. #6
    May 2017
    Hi, Ecufix
    I have a soft which i used to reprogram 24C02, but i can't.
    I have errors message.
    How can i reprogram Ecu?
    Which soft must i use?
  9. #7
    daniersms's Avatar
    South Africa
    You can use almost any serial eeprom programmer
    Love this forum
  10. The Following User Says Thank You to daniersms For This Useful Post:
  11. #8
    May 2017
    Can i use a software?
    Which?
  12. #9
    electrones's Avatar
    Feb 2012
    Around C.V
    Dear friend
    Any eeprom programmer u can read-write 24C02 ex: UPA, willem programmer, carprog,G540 have a lot programmer to do this job
    Try to clean pins and try..
    With which SW u read u original immo !!??
    Cheers
    Press "THANKS" button. just one click, CHEERS
  13. The Following User Says Thank You to electrones For This Useful Post:
  14. #10
    May 2017
    Thank you much.
    I used Immokiller 1.10.
    I wanted to write the file into device but i have errors message finally.
    I can still start the car, but it always turns off after.
    The problem is that the reference of my Ecu doesn't appear in Immokiller, in the VAG part. There is no Bosch Motronic MP9.0.
    Maybe is the reason it doesn't work.
  15. #11
    May 2017
    You tell me to clean pins and then try.
    Do I have to manually make something on the chip in order to reprogram and have immo off?
    I thought I could reprogram 24C02 only with a software, like Immokiller, for example.
  16. #12
    May 2017
    Hi, no more posts!
    Can someone help me please?
