Results 1 to 14 of 14
    levisdj's Avatar
    EcuLand
    Default Ford Mondeo 2009 DPF OFF
    Hi can someone remove DPF from this 2009 Mondeo, ecu is Sid206 read by OBD... 6G91-12B684-BA, also is it safe to re-write via OBD with FGTech ? Thanks in advance!
    Nov 2015
    Lublin/poland
    Quote Originally Posted by levisdj View Post
    hello mate
    dpf off
    press thanx and rep
    test and report
  3. The Following 2 Users Say Thank You to kostrz3 For This Useful Post:
    levisdj (27th July, 2017), Stelaras (28th July, 2017)
    levisdj's Avatar
    EcuLand
    I can't unzip it!
    Nov 2015
    Lublin/poland
    I can't unzip it!
    instal new version winrar 5.50
    http://www.rarlab.com/download.htm
  6. The Following User Says Thank You to kostrz3 For This Useful Post:
    levisdj's Avatar
    EcuLand
    Is it safe via obd to write ?
  8. #6
    levisdj's Avatar
    EcuLand
    Anyone flashed SID 206 with Galletto via OBD? is it safe ?
  9. #7
    Nov 2015
    Lublin/poland
    Yes possible
    Wysłane z mojego C6603 przy użyciu Tapatalka
  10. The Following User Says Thank You to kostrz3 For This Useful Post:
  11. #8
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    EU clone do this with no problem.
    regards.
    DSG TUNING
    File Service
  12. The Following User Says Thank You to maajkii For This Useful Post:
  13. #9
    levisdj's Avatar
    EcuLand
    It worked great, thanks alot!
  14. The Following User Says Thank You to levisdj For This Useful Post:
  15. #10
    levisdj's Avatar
    EcuLand
    Hi, car came back today, what the owner said is that it has lack of power and smoks alot, not DTC stored no MIL...!
  16. #11
    Sep 2016
    EU
    try and report
  17. The Following User Says Thank You to claudio81 For This Useful Post:
    levisdj (8th August, 2017)
  18. #12
    levisdj's Avatar
    EcuLand
    It works better, but still smoks!
  19. #13
    Sep 2016
    EU
    Check injectors debitmeter and turbo parameters. See if they are ok
  20. The Following User Says Thank You to claudio81 For This Useful Post:
  21. #14
    Sep 2016
    heh, good dpf off you have when you dissconect differential pressure sensor and temp sensor so when you write this file solution is bad, the same situation in this car have when cut egr
    FILE SERVICE
