Results 1 to 4 of 4
    Jan 2017
    Default dimsport bin file too dim
    i'm using dimsport 555 bdm to read files, i can see advanced setting that can export the files separately, but those options inside advanced are all gray out.
    is there a way to enable them? or any way to convert separate files back into .dim file?
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    DIM is full backup compressed and crypted by compression algorithm.
    What ecu type ? Probably u have some firmware problem or device is some slave type.
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
    Aug 2012
    Quote Originally Posted by arasnt View Post
    why u will do it u can write any file seperate without check
    use ecu not tuning file
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    Jan 2017
    ecu - sid803a volvo v50
    box - bdm100 clone
    old dimsport555 can only save .dim format
