Results 1 to 2 of 2
    i_shot_the_sheriff's Avatar
    Nov 2008
    Default Smart 450 Gearbox fault 3 LINES
    Good evening mates,
    I have this weird case on a Smart 450 diesel . Client changed the whole gearbox because of a problem and after that when trying to put a lower gear you would hear GRRRRR ! Anyway , many problems with it but you could drive the car..... So they decided that the new "gearbox" needs programming and reset.....
    So , when i tried to program it with star (adaption of gearbox) i hear click click click many times ,,,,, i drive the car and THE SAME problem as before!
    So i try to program it a second time ..... the second time 3 lines appear on dash,,,, now car won't even start and i have DTC P1919 ! I tried resetting clutch, gearbox , removing battery ,,,, EVERYTHING ! car won't start and the 3 lines won't go away .....
    Can anyone help please? HAve you seen that before?
    Thanks in advance
    Portugal
    Hello.
    Have you solved the problem yet?
    The symptoms are by chance these are going to walk and when change of changes appears the 3 traits and the car enters in safe mode (does not walk). If this is the case, take a look at the engine that causes the changes that an oil infiltration may cause and causes this malfunction.
