Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: vcds lite 1.2
    May 2017
    Default vcds lite 1.2
    hello i search vcds lite 1.2 for cable kkl blue
    i search a full version cracked or patch....
    please
    May 2017
    the version 409 is not compatible windows8 .....
    May 2017
    Can anyone help me ???
    May 2017
    Quote Originally Posted by Qwarz View Post
    Here is link to VCDS Lite 1.2
    big thank
    i test now
  5. The Following User Says Thank You to nicolasab For This Useful Post:
    Feb 2018
    Did you got it to work ?
    Aug 2019
    Hey, need some help for activating vcds lite. Does anyone share with me program and loader. Thank you.
    Dec 2014
    PL
    inntibah
    Hi.
    Could you read carefully?
    Link to the Vcds lite 1.2 software is on this page.
    VCDS LITE 1.2 has a loader in itself. You must install the Vag kkl interface in such a way that the com port in DM has number 1. Once you do this, you must do the compatibility test in the "OBD II" tab, and then the test in "OPTIONS" (or vice versa). Finally, after checking in "ABOUT" the license should be "green".(valid /activated). Try and report.
    May 2020
    Thanks so much. Have been looking for this to try it out and see if its enough or if I need the full VCDS (not lite) =)
  10. #9
    Jun 2020
    I registered and still can't download the link yet
  11. #10
    Dec 2014
    PL
    Quote Originally Posted by Kondaraa View Post
    Maybe you should have done "Introduce Yourself"?
  12. #11
    Jul 2020
    I'm looking for VCDS Lite Loader... someone can help me? Best
  13. #12
    Dec 2014
    PL
    Quote Originally Posted by giubenez View Post
    I think you should read the posts on this page carefully. Then you will find a solution to your problem and this what you are looking for.
    It is only one page.
    Good luck.
  14. #13
    Aug 2020
    Is this file still existing?
  15. #14
    Sep 2020
    Hmm, cannot download despite making intro. My Audi 80 is crying for help
  16. #15
    Dec 2014
    PL
    Quote Originally Posted by LondonTech View Post
    Hi.
    Read PM.
