Results 1 to 8 of 8
    Default Samsung Tocco Lite SGH F480 Master reset Code
    Model: Samsung SGH F480
    *2767*3855#
    Use this to reset your phone if you have forgot your pin number
    Turn of phone remove battery, then remove sim card, replace battery without sim card, turn phone on and enter code, then wait for phone to reboot itself (do not turn phone off as this could cause problems, so make sure plenty of charge is in the battery). When it has rebooted it is now unlocked.
    Warning ! if you have anything on the phone you would like to keep then back it up as it will wipe all the memory!
    Jan 2009
    leeds
    cheers worked a treat thanks again
    Canker_Canison's Avatar
    12th Level of Hell
    This code will work on nearly all Samsung phones. I would suggest you leave a SIM in the phone as some models won't allow you to enter the code without one.
    Canker
    "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
    - The Baby Eating Bishop of Bath & Wells
    [COLOR=Green]
    Western Cape, South Africa (Ex-UK)
    This code will not Unlock your phone!
    On many Samsung's it will also not reset the user password!
    hi my niece locked her samsung tocco lite and cant remember what password she entered .
    has anyone any ideas on how to fix this ??
    any help would be much appreciated
    Quote Originally Posted by lawrencef View Post
    Keep in mind that the following will wipe anything not on the SIM or Memory Card!
    *2767*3855#
    12th Level of Hell
    The only other ways to reset the code are to take it to a shop that unlocks phones, or flash the phone.
    Option 1 is the easiest but not free.
    Option 2 needs samsung USB drivers, the latest firmware for the phone, multiloader v5.56 flash tool & the tutorial so you know what to do.
    Visit here & become a member, if you don't join you can't download the files & programes you will need.
    Canker
    [COLOR=Green]
    Feb 2012
    Thanks man you helped me a lot
