Results 1 to 8 of 8
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Default 2015 Subaru XV Crosstrek Hybrid Problem "Collision Detected Hybrid System Function"
    Very interesting problem here.
    Just got this Subaru into my shop after side collision.
    Cleared the module and the airbag light is OFF, no codes displayed in the SRS.
    On the main Screen this message poped up (please see image):
    "Collision Detected Hybrid System Function Not Operating"
    I am using SSM3 and I can not find the way to fix it. All the systems are OK, no codes are displayed in the SSM. I already checked all the fuses and re-seated plugs that go to the high voltage battery.
    Any ideas where the error might be stored?
    Thank you!!
    lwood's Avatar
    city of angels
    its a sensor that goes in the front of the vehicle.. it doenst have to do with SRS. the sensor is to slow the vehicle down if going to hit something..
    DON'T JUST SAY PRESS IT.....
  3. The Following User Says Thank You to lwood For This Useful Post:
    slavax (11th August, 2017)
    Jul 2016
    What you need to do is just clear all past faults in all modules.
    I have done this few times and it works. Make sure you have no previous faults stored In hybrid ECM Battery and so on
  5. The Following User Says Thank You to Grucha1981 For This Useful Post:
  6. #4
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Thank you Grucha. I did not clear "Past Faults" and that was my problem.
    Even though "HEV System" did not have any current DTCs listed during regular scan it had bunch of "Past Faults" listed.
    Just came back from a 20 minute test drive and have to say that after clearing "Past Faults" Hybrid System works as it should.
    Topic closed, thank you all!!
    May 2015
    Quote Originally Posted by slavax View Post
    How did you read "PAST FAULTS" ? with what kind of scanner ? i have same issue with my car now. I tryed read with launch x431, i dont have any fault codes. Thank you i really need help
  8. #6
    Jun 2012
    Launch won't work, you need to use Subaru Select Monitor or Autel Maxisys, I use Elite, and I love it.
  9. #7
    May 2015
    Quote Originally Posted by AVDIMON View Post
    Ok I’m about to use with Autel maxisys. Thank you so much for info. Will keep update.
  10. #8
    May 2015
    Quote Originally Posted by nasim4949 View Post
    For some reason I can’t clear this past fault.
    P1c1e - auto-disconnected experience
