Results 1 to 15 of 16
    Duracell2's Avatar
    Apr 2017
    Default Key remotes for VW - meaning of letters at the end
    Some of key remotes for VW:
    1J0 959 753 B
    1J0 959 753 N
    1J0 959 753 A
    1J0 959 753 F
    1J0 959 753 P
    1J0 959 753 DA
    1J0 959 753 AH
    1J0 959 753 CT
    1J0 959 753 AG
    Do those letters at the end (B,N,A,F,P,DA,AH,CT,AG) have some meaning ?
    P&D's Avatar
    Duracell2's Avatar
    Apr 2017
    But I still don't get it.
    What is the difference between this 3 models. What is A, what is N and what is F ?
    Which one I should buy if I have a VW GOLF IV 1998-2002 ?
    VW GOLF IV 1998-2002 1J0 959 753 N
    VW GOLF IV 1998-2002 1J0 959 753 A
    VW GOLF IV 1999-2002 1J0 959 753 F
    p1et's Avatar
    Oct 2013
    1J0 ... N is newer type (square shaped) and 1J0 ... A is older type (round shaped) and about F letter I don't know, never saw this.
    Duracell2's Avatar
    Apr 2017
    Quote Originally Posted by p1et View Post
    F is 3+1 button
    p1et's Avatar
    Oct 2013
    Maybe it's for USA market - 315MHz. Generally, look at links in post #2 - there is all useful info.
    yugo45's Avatar
    1J0 959 753 F ---- 3 +1 button 315 MHZ (round shaped remote), 1998 – 2001 (1J0 CCM)
    1J0 959 753 N-----2 button 433MHZ (square shaped remote), 1998 – 2001 (1J0 CCM) It can be update for 753 A
    1J0 959 753 A------ 2 button 433MHZ (round shaped remote), 1998 – 2001 (1J0 CCM)
    1J0 959 753 B----3 button 433 MHZ (round shaped remote), 1998 – 2001 (1J0 CCM)
    1J0 959 753 P -----3 button 433MHZ (square shaped remote), 1998 – 2001 (1J0 CCM) It can be update for 753 B
    1J0 959 753 DA------Update for753AH
    1J0 959 753 AH------3 button 434 MHZ (square shaped remote), 1998 – 2006 (1C0 CCM)
    1J0 959 753 CT------ update for 753AG
    1J0 959 753 AG-----2 button 434 MHZ (square shaped remote), 2000 – 2008 (1C0 CCM)
  8. The Following 4 Users Say Thank You to yugo45 For This Useful Post:
    doctore (16th August, 2017), Duracell2 (16th August, 2017), LKEY (26th August, 2023), Matronix (30th July, 2023)
    Duracell2's Avatar
    Apr 2017
    Quote Originally Posted by yugo45 View Post
    Dear Yugo, what means "DA------Update for753AH"... Does it mean that I can use DA instead of AH ?
  10. #9
    Oct 2015
    Quote Originally Posted by Duracell2 View Post
    Yes, same situation with 1K0959753 it is superceeded by 1K0959753G
  11. The Following 2 Users Say Thank You to klesk1986 For This Useful Post:
    Duracell2 (16th August, 2017), yugo45 (19th August, 2017)
  12. #10
    Jul 2023
    Hi to all,
    I have bought 1J0 959 753 N (square) from china.
    But with VAG-COM, I cannot add this board to my CCM 1J0 959 799 AH
    No problems with other 2 boards 1J0 959 753 A (round).
    Is 1J0 959 753 N board compatible with my CCM?
    Other question: I see that some sellers says: 433 or 433.92 or 434MHZ.
    But there is an:
    1J0 959 753 N 433MHZ
    1J0 959 753 N 433.92MHZ
    1J0 959 753 N 434MHZ
    Or is the same board?
  13. #11
    p1et's Avatar
    Oct 2013
    As written above, 1j0 ... N replace 1j0 ... A.
    I suspect they sent you wrong remote because normally those chinese remotes were OK.
  14. #12
    Jul 2023
    I suspect too, in particular on the box I received it says "1J0959753N, 434MHZ".
    But 1J0959753N, should be 433MHZ or no?
    however, In the website of seller there's written 433MHZ
    PS. red led blink OK but CCM don't "read" this board
  15. #13
    Jul 2023
    Anyone have details?
    433MHZ is the same of 434MHZ?
    Is there only one version of 1J0959753N? only 433MHZ?
    Seller say that board "version" is ok...
    Is problem of my CCM (1J0 959 799 AH)?
  16. #14
    Oct 2020
    Bulgaria
    Same problem here. My friend order 1J0959753N 433mhz from aliexpr. Car is Seat Leon 2000year with 1J0 959 799AH unit. I cant make this to work. When try to adapt remote with vcds there is confirmation (horn signal) but nothing adapted, remote not worked. Tried many times, but not work. I get error incorrect key adaptation... or something similar.
  17. #15
    Jul 2023
    Quote Originally Posted by evgeny87 View Post
    Same problem here. My friend order 1J0959753N 433mhz from aliexpr. Car is Seat Leon 2000year with 1J0 959 799AH unit. I cant make this to work. When try to adapt remote with vcds there is confirmation (horn signal) but remote not worked. Tried many times, but not work. I get error incorrect key adaptation... or something similar.
    And for yuor friend with an genuine key 1J0959753N work?
    I have tested only 1J0959753A with my ecu (1J0 959 799AH)
