Results 1 to 15 of 18
    Aug 2016
    Default Lexus rx300 2003-53 immo location
    Hi can someone tell me where immo is located on lexus lx300 2003 and which transponder im using,
    Jul 2016
    The transponder is 4D and you have to remove the dashboard to get access to the immo ecu.There's a shortcut if you don't want to remove the dashboard you have to remove the blower housing then slide your hand inside
    The dashboard and then look inside...it's mounted with a 10mm.
  3. The Following User Says Thank You to fahmidhassan For This Useful Post:
    garagetech007 (17th August, 2017)
    ray-ray's Avatar
    WRONG! Rx300 is a 4C chip the immo is inside the ecu, behind the glove box. The target is a 93lc56 the pcb is printed (IC900).
  5. The Following 4 Users Say Thank You to ray-ray For This Useful Post:
    bursuc (27th October, 2017), fahmidhassan (18th August, 2017), garagetech007 (17th August, 2017), hass42 (11th September, 2017)
  6. #4
    Aug 2016
    Im working on it today will report back boys thanks for the info
    Jul 2016
    Quote Originally Posted by ray-ray View Post
    i agree with you sir...
    but i worked on a japanese RX300 couple of months ago and the immo ecu was right underneath the dashboard (mounted on heater core/evaporator housing) and the EEPROM was 93c66 don't remember the key(probably 4D/ ID67) and the immo dump was as same as ES300
    BTW...thanks for correcting me
  8. #6
    Aug 2016
    Update is i manage to have coms with immobiliser in car with avdi , it reseted immo successfully at first i used 4c chip and security light didn't go off with fault showing wrong chip So then i used id67 and this also no start with fault B2794 unmatched encryption code after this i put 4d chip same fault with this also
    Can u boys guide me where im going wrong in the mean time ive got ecu thinking immo is in ecu .after disconnecting ecu immo light still flashing!!!
    No chips on back board of ecu however plenty 8 legs on front of ecu i can see l56r chip ???
    Where is immo eprom if its in ecu?
  9. #7
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    If it has an immobox i suppose it should be : If not attached to ignition cylinder then it gotta be behind the radio.
    Try id68. In my country it's called Harrier and i did a 2004 before and the chip for it is id68
    How many keys did you learn to the car back then? Are you sure the procedure is correct?
  10. The Following User Says Thank You to ucokseparoh For This Useful Post:
    garagetech007 (20th August, 2017)
  11. #8
    ray-ray's Avatar
    In the USA RX300 = 4C all lost key eeprom only. RX330 =4D68 all lost keys via obd2. IC601 with (l56R)
  12. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    garagetech007 (20th August, 2017), ucokseparoh (21st August, 2017)
  13. #9
    Aug 2016
    Hi when i open l56r in avdi its asking to virgin but only see it as ecu denso not immobiliser?
  14. #10
    Aug 2016
    They're is also another 93c86 on board! Could this be it?
  15. #11
    Jan 2017
    USA ����
    ok first things first
    did you try to start the car with a metal key?
    did you check under the dash for a aftermarket alarm system?
    did you read the correct chip?
    ic900 should be correct chip for the 2003 rx300 93c56
    but if its 2004 it should be ic2 93Lc56
    where was the ecu???
    also what is the VIN number did you check it to be 100% sure of the year?
    if it is a 2004 you need to pull the IMMOBILIZER BOX and NOT THE ECU
  16. The Following User Says Thank You to sleepyrz For This Useful Post:
    garagetech007 (21st August, 2017)
  17. #12
    Jan 2017
    USA ����
    also there are two different files depending on the country of manufacture...............
    usa and japan have different files for the 2004 immo
    but if its a 2004 you should just use the damn orange reset tool and get the hell out of there in 15 seconds
  18. The Following User Says Thank You to sleepyrz For This Useful Post:
  19. #13
    Aug 2016
    Quote Originally Posted by ucokseparoh View Post
    I reseted immo box avdi says 0 master key and 0 sub and when i put 4c,4d,67 in turn non of them are excepted, immo light flashes and key is not registered!
    With id68 which page i need to generate ?
  20. The Following User Says Thank You to garagetech007 For This Useful Post:
    Konstantin123 (6th July, 2018)
  21. #14
    Aug 2016
    Thankyou very much for everyone who helped
  22. #15
    Aug 2016
    [QUOTE=garagetech007;3093878]Thankyou very much for everyone who helped,the car started Dk is dk i love dk
