Results 1 to 7 of 7
    nickolasd's Avatar
    Nov 2015
    Default 2010 VW golf VIN number change
    2010 VW Golf GTI 2.0T
    I'm looking for any help how to change vin numbers
    ECM med17 1K0907115AQ
    dashboard 5K6920971C
    IMMO 5K0953234
    Steering assist module 1K090914H
    Maartinj's Avatar
    Nov 2010
    VVDI2 over OBD can do
    nickolasd's Avatar
    Nov 2015
    i have vvdi2 full, and tried everything in it, can't find anything vin number related. dump tool for med17 doesnt work.
    Maartinj's Avatar
    Nov 2010
    Run ECu adaptation, and write NEW VIN and SAVE , ECu will learn itself ,
    Cluster - read immo data , change vin, write
  5. The Following 3 Users Say Thank You to Maartinj For This Useful Post:
    amigokola (25th August, 2017), lock66 (30th January, 2020), nickolasd (26th August, 2017)
    nickolasd's Avatar
    Nov 2015
    i was able to do cluster just as you said, but ECU fails to read, VVDI2 can't read it, gives en error "function only for authorized condor users"
    nickolasd's Avatar
    Nov 2015
    can somebody take a look on this med17.1 dump and change vin number
    old vin WVWED7AJ7BW1900020
    new vin WVWED7AJ4AW068360
    it looks like vvd2 can do that by a dump or obd, but only with condor authorization.
    i tried manually change vin number in eeprom and write it back but i get no start and eeprom error dtc.
    nickolasd's Avatar
    Nov 2015
    problem solved, mistake was in checksum calculation for eeprom. FG galleta clone could not do calculation.
