Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 92
    Nov 2008
    Default Vag Tacho 2.2-2.5-2.6-3.1 dump files
    Anyone can help users to repair Vag Tacho cables killed by using higher version of software please post here.
    The only solution I have is to repair 2.5 cable by downgrading to 2.2... wich is a bit unacceptable.
    Attachment here contains solution to repair your cable.
  2. The Following 9 Users Say Thank You to k4talin For This Useful Post:
    ELECTRODIAG (5th December, 2015), guliver21 (6th January, 2023), IstvanLaszlo19 (9th May, 2018), joe06 (24th February, 2025), nobbny (29th July, 2022), nth2 (11th October, 2015), opel17 (23rd December, 2015), RadioUser (2nd January, 2023), raductn (5th January, 2023)
  3. #2
    EARTH
    Use mprog 2.8
    Program with file VagTahoUsb22.ept
    Then run VTU-2XX-UA.exe
    Removing and Replacing the usb.
    Ready.
    Perfect
    dasboard3's Avatar
    hi friend
    please upload rapid or mega thank you
    Quote Originally Posted by k4talin View Post
    Quote Originally Posted by datapage View Post
    Use mprog 2.8
    Ready.
    Perfect
    Hello
    here i can found vtu-2xx-ua.exe
    Mavi
    Does any one have soft to 3.01 china clone been looking for a while now. Pm if you post going throught chemo right now only get my weekends and feel like doing nothing but watching the telly.
    germany
    very efficient!!!
    the ID was blank....
    Default vag tacho 2.2
    interface not found
    Smile HOW TO UPDATE THE VAG TACHO 1.4
    Can anybody tell me how to upate the vag tacho 1.4 to 2.2 or 2.5 with mprog ?
  10. #9
    k4talin please reupload becose file is corrupted and cant be extraced
  11. #10
    Junior Member max4ever's Avatar
    Romania
    C4talin - Please reuploaded in .rar format...Please,please,please...because my vagtacho v.2.2 China wrote "Connecting VDO New...
    Unsupported Command!"
  12. #11
    hi friend
  13. #12
    Romania
    After i've used K4talin's software, it seese the interface but I have the same error :
    "USB to K-line Interface Connected!
    Try to Connect Kombiinstrument at 9600 bps
    Try to Connect Kombiinstrument at 10400 bps
    Please help me!!!!!
  15. #14
    Barcelona, Venezuela
    Talking
    Thank you so much, I upgrade my old vagtacho no problem!!!..
  16. #15
    I have the same problem than max4ever.
    I repaired my 2.5 cable with the software.
    Vag Tacho 2.5 seem to be OK (interface found ID ....).
    But I can't read any Dash.
    -> Unsupported Command .......!
    -> connect with "any Tacho" is an endless loop trying each Bout rate.
    Please help! ****ing Vag Tacho 3.5 destroyed my cable!
