Hi Guys,
I would like to add a second key to a Peugeot 107. I have a working master key which starts the engine / opens and locks the doors.
I obtained a used key from Ebay, had the key blade cut and managed to make the remote work so it now opens and closes the doors but I can not program the immo side to the car. Peugeot Planet always gives the followign error:
"Error in the key learning
The key has not been registered in the immobiliser control module"
This is after selecting:
Immo control unit -> Key programming -> Learning new keys -> Learning using the master key
The already programmed (master) key had to be insterted into the car, then following the prompts the tool then asked for the new key, went through the programming and at the end when it does the verification it failed.
Any suggestions?
Thanks,
Tibi
