Results 1 to 9 of 9
    lwood's Avatar
    city of angels
    Default 2000 Lincoln Navigator
    i have a problem with a 2000 Lincoln Navigator. customer brought in vehicle. remove cluster to fix. when cluster was remove customer try to start vehicle. the Navigator would not start. now when install cluster back on. vehicle will not start..THIFT light stay on.. i disconnected battery for 10mins that didnt work.
    scan tool gives code B1845 ignition tamper circuit fault, P1260 if theft is detected, vehicle is immoblized.
    how to fix??? please and thanks
    DON'T JUST SAY PRESS IT.....
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by lwood View Post
    Try one sulution ,need to actual key. for syunhro.its mean 1. key turn ignition 5 sek turn off put 2 key turn ignition and antiteft most go .
    lwood's Avatar
    city of angels
    i dont understand. could someone elaborate??
    brend's Avatar
    Oct 2015
    Same where
    Whats mean elaborate?
    ascrap2003's Avatar
    Sep 2016
    Texas
    i think he means to put 1 key in ignition turn on position for 5 seconds, remove and do same with key 2 and it should verify keys I think.
    If not i belive you need a good scan tool snap on, maxisys etc & 2 keys and do paremeter reset I think. Not sure if you need J2534 or not. Maybe theirs a easier way someone will come along and help!
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
    FxShaw's Avatar
    Nov 2013
    Outta This World
    This will work only if the customer have 2 keys to begin with. if he doesn't then you will need to get a 2nd key cut and then parameter reset. pats for this vehicle is obviously in cluster like most ford. possibility it's a time limit lockout and after waiting 15-30 mins, try to start again with key.
    🔥Wacka Wacka 🔥
  7. The Following User Says Thank You to FxShaw For This Useful Post:
    ascrap2003 (1st October, 2017)
    ascrap2003's Avatar
    Sep 2016
    Texas
    Quote Originally Posted by FxShaw View Post
    Could you point me in the right direction for this proccess? will this always work if lets say batteries die and car goes haywire? Besides if a an actual pats component goes bad such as key "transmitter", key switch "receiver" etc?
    Is it the same proccess for a cluster swap/replace?
    lwood's Avatar
    city of angels
    i will ask customer . if have extra key
  10. #9
    Oct 2013
    Some fords need only 1 key to do a parameter reset even if the manual or scanner tells you so. Worst case just remove the transponder coil and use a key with the same type of transponder. No big deal.
