Hi DK, i have a fault appearing on my dashboard anti pollution fault, along with a annoying beeping sound, and a orange light staying on in the car dash, any help in clearing these faults on my car would be appreciated, cheer's.![]()
could be a number of thhings, mass air intake sensor.fap filtter. turbo sensor. without the codes you looking in the dark m8. just done mine it turned out to be the egr valve stiking. just some thing for you to look at. if you need the codes reading i have a scanner if you live in hampshire area
thanks for the reply boots, i live in glasgow, but i ] have been told it may be a fuel problem i.e. filling up at supermarkets asda, tesco ect, i will llet it run down near empty then fill up with a premium grade at B.P. SHELL ect then let you know if it works to clear it, thanks for the code offer but i would not know what to do with them, cheers.![]()
the other half did that i just put some diesel cleaner in it slic5 halfords.and i always stay with bp or esso
is it a diesel car with a dpf in exhaust,it is a modified exhaust which goes at around 70th miles,cause wrong oil been used in engine as needed a low ash content oil,hope i am wrong as it is expensive to repair.usually main dealer only repair.
diesel particulate filter.
Hi Kid, its a petrol 1.4 engine
maybe hook up to diagnostics for fault codes,only way of knowing what it is,glad it is not a diesel.
I accidently filled my Peugot 307 diesel with petrol.I took the car to a mechanic friend of mine and he drained the tank and filled it back up with Diesel.Car is running perfectly except I have an orange symbol looks like an engine on the dashboard and the words anti pollution comes up o the display.
Can anyone tell me what the symbol means and what the anti-pollution warning is plz and how I would go about getting rid of the symbol and the warning.
hi orange light is the mill light (check engine) and anti polution light might go out after a few tanks of diesel through it. also recommend putting some slick50 in the tank and take it down motorway in 4th gear keeping it above 3000 revs to force regen exhaust to help with the flush out. hopefully it hasent cloged the fillter in the exhaust very expencive. good luck
Take the car to a dealer, have the diagnostic trouble codes read and based upon what you find decide what to repair.
Continuing driving with the problem may damage the particle filter and those are expensive.
jeeze i've been driving mine for a couple of months with the same fault. happened a year ago and had it cleared because it put me into ''limp mode.....max 2200 revs''. going in for mot shortly so i will get it sorted...cheers
Cheers guys will try bigboots theory 1st to see what happens and then if problem doesn't go away it will be sent to the dealer.
Doiesn't need to be a dealer, they are usually more expensive than independents, ask around and try find a garage that is recommended by a friend, call them and ask if they have suitable diagnostic equpiment...... Your in Glasgow I am sure half the garages there all use PPS software
Hi Jimcee
Well, lets first sort this thing out Is Your Car Petrol or Diesel ?
Second thing NO Metter weather your car is Petrol or Diesel on Peoguet when you have Engine Fault you will see the Message saying Anti Pollution fault because its a Emission fault.
Now the best bit for you to do is As adviced by Oldford get the Car diagnosed by any garage whos got diagnostic kit and see what fault codes are and see what they advice you.
If you not sure than just post those codes here and we will try and help you out..
Hope This Helps
Ash
