Results 1 to 10 of 10
    Aug 2013
    Default 2008 Land Rover LR2 HSE Slot Key Add Key No Crank
    Used Abrites Original and then it added key from 2 to 3 key counts, remote works but no crank with either original or new aftermarket key. Tried erasing, now 2 keys in system, same problem.
    Tried SKP900, same problem.
    Tried TCODE, same problem.
    Tried hard reset by disconnecting battery for 5 minutes, nothing.
    Checked DTCs with Abrites and cleared, nothing.
    So it releasing steering lock, dash turns on, the red security light goes away, but no crank. Seems like it's still in programming mode, or a code not allowing car to crank.
    Might have to go to dealer if no hints from here by tomorrow.
    doctore's Avatar
    Nov 2015
    Colorado Denver
    if the red security light goes away, but no crank,tr direct on starter to see if will crank and start
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    Aug 2012
    outerspace
    Maybe starter faulty !
    Jan 2016
    These also suffer earth problems. Put a jump lead from battery to earth starter, and retry.
    ThiagoArgentino's Avatar
    May 2016
    Brazil
    Friend,
    I already got this bug in keys coded by Abrites.
    You will need an SSD (Land Rover) to get this car back to normal. You just need to reschedule your car's ABS again, and it will work again with the original key and the copy key you recorded ...
    Defect detected and resolved after programming vehicle ABS
    Do not send the car to the dealership, because they condemn several modules and charge an absurd price to solve ...
    Solutions in the area of automotive coded keys, all automakers.
  6. The Following User Says Thank You to ThiagoArgentino For This Useful Post:
    duplikeytor (15th October, 2017)
    Aug 2013
    Quote Originally Posted by ThiagoArgentino View Post
    Friend,
    No other way to resolve this matter without SSD? Is there an offline version?
    electromech's Avatar
    Behind a large rock
    Autologic will do it too
    May 2016
    Brazil
    Quote Originally Posted by duplikeytor View Post
    Yes, I solved with SSD clone, offline ... I believe that any equipment that does ABS programming, will also solve your problem ...
  10. The Following User Says Thank You to ThiagoArgentino For This Useful Post:
    duplikeytor (17th October, 2017)
  11. #9
    Aug 2013
    Please PM where I can get me a SSD Clone. THANK YOU!
  12. #10
    If is your problem with configuration
    use function Module inicialization in abritus.
    But 99% you have another problem (immo lapm go off, dash turn on etc).
