Results 1 to 4 of 4
    Jun 2012
    Default kia sportage 2crdi problem after dpf off p2002
    hi we had a kia in for dpf off
    after we install tuned map and dpf off file
    edc16 ecu
    we have strange code p2002 we clear and then reappears light on dash no limp mode
    we then put orig map on and try to do a dpf replace procedure with diagnostics and all diag tools fail,
    snapon launch and Delphi,
    so we cant do a dpf replace procedure,
    only thing will say is mechanic damaged the dpf sensor after we nocked out dpf,
    any idea ? the mod should have p2002 disbled yet still we have a light and this code
    think maybe we need to replace the sensor ? to allow replace procedure
    help anyone cheers
    Oct 2017
    It’s Dpf codes I don’t think all Dpf codes have been deleted
    Mar 2016
    Sweden
    Default KIA
    YOUR DPF OFF FILE
  4. The Following User Says Thank You to sonic 1989 For This Useful Post:
    pulsar2000 (23rd October, 2017)
    Jun 2012
    Quote Originally Posted by sonic 1989 View Post
    YOUR DPF OFF FILE
    good worked thanks
