Results 1 to 7 of 7
    Dec 2010
    Default CAN-AM Maverick X3 2017
    These are pictures from CAN-AM Maverick X3 ECU.
    The dash has 9S12HY64 and i already read it with UUSP.
    The km is stored in dash, while the Hours are probably stored in the ECU
    that i attached it's pictures.
    I don't want to damage anything while opening this MCU, so if some one
    already dealt with this ECU, i'll ask him to assist me with advise.
    THX for any info about this ECU.
    May 2015
    I'm able to change hour in this bosch ecu with buds megatech software in watercraft but never try on aide by aide...
  3. The Following User Says Thank You to Berubeg For This Useful Post:
    junmab (26th October, 2017)
    Nov 2015
    Detroit
    Same Ecu as the seadoo can read it with ktag my friend
  5. The Following User Says Thank You to BYTES For This Useful Post:
  6. #4
    Dec 2010
    Quote Originally Posted by Berubeg View Post
    "buds megatech software in watercraft" these are really strange terms for me...
    May 2015
    Buds is the brp diagnostic software and megatech version is the higher version possible. More possibility than the dealer version. On snowmobile is possible to reset hours to 0 only and on seadoo is possible to set to desired hours.
  8. #6
    Oct 2020
    There are 2 hours: Engine and Vehicle hours. Vehicle hours (shown on dash) can be changed with BUDS/BUDS2. Engine hours on eeprom. With buds/buds2 you can wipe (0 hours on both) but you need to save info (engine number, vin, cdid info) and wipe EEPROM, only leave top info on eeprom, reflash eeprom then you will then need to reprogram all the info back but some BRP have "break-in" where vehile needs minimum hours to work 100% full throttle.
  9. The Following User Says Thank You to edgararroyo For This Useful Post:
    llanesluna (6th October, 2022)
  10. #7
    gogalv's Avatar
    Aug 2010
    Everything can be done through the dump. And you can make a lot of values in the ECU.
    You'll need pictures from all sides mate .... ? PremierD
