    number7hd's Avatar
    Dec 2013
    Default RNS 510 - problem with updating maps - suspected HDD
    I have made new map instalation in RNS 510 by DVD+Sd card. I made it many times before.
    Usually I was waiting 20-30 minutes, then apears FINISHED SUCESSFULY.
    In this case I can wait even 60 minutes - copying process can't be finished.
    I think it is becouse of bad sectors on HDD.
    Does anybody has similiar problem?
    If my solution helped You - do not forget to THANKS !!!
    number7hd's Avatar
    Dec 2013
    SOLVED
    HDD replaced and everything is OK now.
    number7hd's Avatar
    Dec 2013
    SOLUTION FOR ALL MEMBERS !!!!!!!!!!!!!!!
    OK - now I know that HDD wasn't guilty...
    MAPS TOOL (copying from SD card) don't erese old maps from DVD directory in RNS510 !!!
    You can wait even week and copying process won't be finished... becouse on partition will not be place to copy map.
    I solved it taking out HDD, deleting manually content of DVD folder and manually copying new maps to DVD folder.
    Dec 2018
    Hi, what is structur files on HDD?
    you can say me, what i can copy maps dirrect on HDD, now is device death, not running, must reload fw.
    THX
    Oct 2018
    Also can use the special CD (2720_mpf) to remove maps .
  6. The Following User Says Thank You to Mikle1 For This Useful Post:
    tecknik (18th March, 2020)
    Jun 2016
    France
    Quote Originally Posted by Mikle1 View Post
    Yes, i confirme the use of the special CD works, ther are also functions accessible with certain tool like the Martech interface. We can format the hard drive and lately also erase the flash.
