Results 1 to 5 of 5
    May 2017
    Default opel insignia audio off
    Hallo
    I have problem with opel insignia 2014.
    I can not turn od radio/navi model Touch R700/Navi 900. LCD panel is black. On dashboard panel is displayed an information - audio off.
    I have read the car with op-com and I have got fault: no comunication with radio U0184
    All fuses are ok. I have disconnected the battery and it did not help too.
    fotos attached
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    You have a problem with Delphi unit,mounted behind the glove box.
  3. The Following User Says Thank You to simaservis1108 For This Useful Post:
    audiopoint (7th November, 2017)
    May 2017
    Do You know how to fix it? Which tool can do it?
    Sep 2015
    Lviv, Ukraine
    Hello. I have the same problem. Can someone advise how to fix the problem?
    Dec 2010
    United Kingdom
    Same problem here. Opel 2010
    Radio dead
    Screen above is dead.
    Signal lights ok but no sound from it!
    U0184 logged in the airbag ecu!
    All fuses checked!
    This happened after the starter relay went faulty and tried to turn over the car! Battery disconnected, new relay fitted. Now have this problem.
