Results 1 to 10 of 10
    Question Lexia 3 - update BSI ?
    Hi there!
    Can someone assist me how can i update BSI (ECU) ?
    How can i download new BSI? From where?
    I have Lexia 3 but i cannot download from regular citroen site 'cause of proxy restriction ...
    I got Citroen C8 2.2 HDI 2003
    Any ideas? References?
    Thanks!
    Default bsi ???
    hi ref your soft wear download . why do you need to up date your bsi soft ???
    dont forget you can up date from your lexia not only internet download to up date , and dont forget you will require your transponder code also or you will be unable to code your key and plips . good luck
    DK Veteran zogldi's Avatar
    Space
    You can update your BSI only from Citroen-ACTIA server,you have not server permission because you diagnostic tool is not orginal tool!You can try manual configuration!
    Ok!
    How can i update it manually?
    Brgds!
    Top Poster citronel's Avatar
    www.psaclub.ro
    Anyone have Citroen account to download BSI or already has an update for C8 2.2 HDI 2003?
    Brgds!
    Space
    Every PSA car have individual data in BSI, because you have VIN,PIN alarm code .... Only way if you havn`t orginal diagnostic tool is make BSI "virgin" and then manual configuration!For "virgin" file you must know eprom is inside BSI (95160,HC912...).Regards
    www.psaclub.ro
    Quote Originally Posted by citronel View Post
    1) install latest Lexia and update by internet to latest 345.57
    2) select menu:
    Downloading
    ECU Downloading
    Select car - Enter RPO
    3) select menu:
    Multifunction unit
    BSI
    Downloading
    follow instruction on screen, if you have latest Lexia and there is latest BSI sw installed then will be uploaded, if not then you need Citro account for download.
    I think on latest Lexia there is sw:
    0B0A
    which correct:
    Improvement in battery monitoring and increase in sound level if headlamps left on.
    and sw 1E0A:
    Fuel sender law / "emission control problem" display when starting the engine / electric window and door mirror RH side / External air temperature.
    Caution:
    be sure your car battery it is charged and car is not in economic mode.
    hi can you tell me where rpo number is on xsaro picasso y2000
    drakov's Avatar
    Aug 2008
    checker inner drivers door pillar or post/pm vin number
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
