Results 1 to 15 of 24
    Feb 2017
    Default Toyota Aqua Push Start Key Programming
    Hi i have a used key i got from Japan to program as normal with a Japanese Toyota Aqua (Prius C).
    However when i try to program it never is successfully added to registered keys.
    I switched batteries between the original and new fobs and tried Toyota TIS, X100 PROS, and IMMO function on Launch X431 and none are able to register the new key. I was even able to delete one of the original keys and the key count went down so i'm sure the software itself is working just not the registration process.
    I'm thinking maybe there is special prep procedure for Aqua or something, but really not sure how to proceed.
    Has anyone done this with the Aqua? Where am i going wrong is there any other tested and working way to do it?
    rob h's Avatar
    May 2011
    Aqua, is like prius.
    You need a working master, to add more Keys.
    Or use Tango, or add key by dump.
    Look for the smartbox!
    Jul 2016
    London
    Quote Originally Posted by daxt0r View Post
    Hi Daxt0r
    You have a working key (you slope the batterys on the keys) As a start?
    You can't register a used key , the key have to be a brand new or used key Made like a new before programming.
    Sent from my SM-G935F using Tapatalk
  4. The Following User Says Thank You to SK Auto For This Useful Post:
    daxt0r (11th November, 2017)
    Feb 2017
    Quote Originally Posted by SK Auto View Post
    Hi Daxt0r
    Hmm i have an originally registered working key as start that is fully working however a spare fob was purchased to be programmed to vehicle.
    How would i go about making the used key like new? Does it have a chip like the instrument panels to dump and change or something?
    Jul 2016
    London
    Tango and mk III what i know works
    Feb 2017
    ok so you are sayin its not possible with any of my available tools?
    Thanks for all the help.
    Jul 2016
    New Zealand
    You can't program USED smart in normal way. You need reset used smart (one you want to add) or manuly reset you immo system and reprogram both (old and new) smars, starting with new one. Zed Fll and some other key programers can reset used Toyota keys.
    Feb 2017
    I do believe my X100 and Launch X431 can do this reset but has anyone actually done this with these newer Japanese Toyota vehicles?
    I don't want to shutdown the car and have no way to reactivate.
  10. #9
    Feb 2017
    after reading online it seems i have to reset the IMMO ECU with Techstream or my X100/X431 then register both keys.
    Has anyone done this with the recent Japanese Toyota's? Is it safe?
  11. #10
    Jul 2016
    New Zealand
    You can't reset immo on Japanese Toyotas with any OBD tools, only manualy (remove ID-box and smart unit, unsold and reprogram eeproms). But with some key programmers you can reset (make like new) used smart key and then add them with techstream in normal way. Zed Full and some other key programmer can reset USED SMARTS, not your immo system. Techstream can reset immo only on USA/Euro toyotas.
  12. The Following User Says Thank You to AEMan For This Useful Post:
    daxt0r (14th November, 2017)
  13. #11
    Oct 2017
    Surga
    For add key you must renew smartkey and delete other not used key in system smart & start.
    And you can using Toyota Techstream Jepung Region for programming add key mode
  14. The Following User Says Thank You to gafelzo For This Useful Post:
  15. #12
    Feb 2017
    Quote Originally Posted by gafelzo View Post
    I'm not sure if you are suggesting to reset key as above suggestion using special RF tool, and then attempt to re-add, or is there another way?
  16. #13
    Feb 2017
    Quote Originally Posted by AEMan View Post
    Can you or anyone Zed-Bull can reset the Toyota key below, so i can then proceed to register with Toyota TIS.
    Has anyone done this? I don't want to buy an equipment if it can't work, i see the CN900 doing it but its quite more expensive.
  17. #14
    Brayn's Avatar
    Oct 2015
    Colombo
    can reset via obd when all lost key situation also
  18. #15
    Brayn's Avatar
    Oct 2015
    Colombo
    used smart key can program for Aqua , just need 10 min, need reset smart ecu then you can program used or new smart keys. maximum 7 smart keys
    if not you can virgin smart key and add key via any key programmer of toyota techstream or any diagnosis scanner
  19. The Following User Says Thank You to Brayn For This Useful Post:
