Page 80 of 89 FirstFirst ... 30707576777879808182838485 ... LastLast
Results 1,186 to 1,200 of 1321
  1. #1186
    Quote Originally Posted by Jim.Mahoney View Post
    I suggest you install the PC based Huawei Mobile Partner, the links are given earlier in this thread! There is no firmware update available for the K3250.
    Yes I have the mobile partner on my desktop - my partner has a K3715 which was flashed (before we bought it) with the generic Mobile Partner software, and so this installed on the desktop is working (select device for K3520, now unlocked), but how do I flash the K3520 ...
    OK, so the firmware on my K3520 until a few minutes ago was version 11.314.12.02.00
    I have now updated the firmware to 11.314.21.31.00 (the most recent that I could find) from here:
    http://www.vodafone.de/downloadarea/...31.00.B418.zip (thanks Tomianek - Huawei forum poster)
    Others such as Medina03 suggested
    11.314.17.00.00 : This version is used in other providers, such as O2 in germany (http://portal.o2online.de/nw/support...ick/index.html) or Optus in Australia (http://help.optuszoo.com.au/help/wir.../connected/usb)
    What I want to know now is, how can I replace the Vodafone Mobile Connect Software VMC Lite 9.3.6.12095 with the Huawei Mobile Partner dashboard on the device itself, so that it will autorun.exe for Mobile Partner appears whenever i plug it to any PC (instead of the current "Run Setup_VMC_lite.exe")?
    Thanks.
  2. #1187
    Western Cape, South Africa (Ex-UK)
    Quote Originally Posted by hash3112 View Post
    Yes I have the mobile partner on my desktop - my partner has a K3715 which was flashed (before we bought it) with the generic Mobile Partner software, and so this installed on the desktop is working (select device for K3520, now unlocked), but how do I flash the K3520 with generic software so the autorunis for Mobile Partner and work on any computer i plug it into?
    I can't seem to access it to delete/overwrite files... and if i try to update, which would be best? I've heard e169 from june 2008, or e160g from 2009, but is these the best choices? With e160g software wouldn't i lose functionality (ie make it work on networks 2100 only no 900, when K3520 should do both)? What about speeds? eg. software allowing for 7.2 down 5.6 up would be optimal - what should i flash it with then?
    P.S. Do you know the Flash code for my device if I do end up needing it later? THANKS!!
    The Dashboard is just that, so the dashboard from a E160 is the same as that used in the E160G although the device is different in the bands covered!
    The flash code is only for non-approved firmware upgrades! This should not be needed to upgrade the dashboard side of the modem.
    Just for completeness your device codes are:
    Flash: 45648426
    Unlock: 53362576
    You need to keep in mind that the K3520 is a device specially produced for Vodafone! If you ask Huawei what the differences are, you'll get a deafening silence!! As far as I am aware it is just a E169 branded for Vodafone but there is always a risk that a later version of the K3520 may be another device re-branded. In fact one Vodafone K series modem suffixed with a -Z is not even a Huawei device but it's actually made by ZTE!!
    The Windows dashboard can be found at the top of the page here: Huawei Terminal
    Technically speaking if you install E169 dashboard onto a K3520 it would lose it's type approval which is quite serious in some countries...
    Personally, I leave all K Series Huawei modems with their Vodafone software on them and supply my clients with either a copy of MDMA or PC installed Mobile Partner. If you are worried about the device trying to install itself each time it is plugged in, MDMA has an option to toggle this facility on and off using a command line option!
    I don't use Vodafone or Mobile Partner but MDMA which is a standalone application that you can copy onto a microSD card on your device. It does not support SMS but it does support USSD commands. Load time is < 0.5 seconds and so beats both VMC and Mobile Partner hands down!!
    You can get MDMA here: MDMA - a Mobile Data Monitoring Application
  3. #1188
    Hi, need unlock code for Huawei E180
    IMEI: 356185036390408
    Many thanks
  4. #1189
    Hu there would it be possible to get me the codes for the.
    Huawei E122
    Operator: 3
    Country: Uk
    Imei: 356881031124046
    Thanks Alot
  5. #1190
    Flash: 56806764
    Unlock: 34256575
    Flash: 66037043
    Unlock: 50294429
    What network was the modem on originally and does it still work on that network? Also what network do you want to now use??
    Flash: 57992008
    Unlock: 66450690
    Thanks a lot worked fine for me.
    ingschud
  6. #1191
    Quote Originally Posted by CYHK2009 View Post
    Many thanks
    Unlock Code : 39072009
    Flash Code : 37394199
  7. #1192
    Quote Originally Posted by guizas View Post
    Huawei E122
    Operator: 3
    Country: Uk
    Thanks Alot
    Unlock Code : 47383251
    Flash Code : 64451957
  8. #1193
    Quote Originally Posted by MKAlex View Post
    Thank you. After entering the unlock code into Huawei Modem Code Writer, I got the following. Can anybodly kindly help?
    Found Phone, Phone Info:
    - Manufacturer :huawei
    - Model :E180
    - Revision :11.126.04.00.157
    - Phone IMEI :356185036390408
    Send Unlock Command... ERROR
  9. #1194
    - Model :E180
    Insert non-accepted SIM and the modem should ask for unlock code! If it does not, use a PC installed copy of Mobile Partner (look back through thread for links).
    I have no idea why you are using code writer it's primarily only for E220 Huawei modems!!
  10. #1195
    Hello there!
    Can U please help me unlock this?
    modem K3520
    Model Huawei K3520
    IMEI 353284022559309
    Firmware 11.314.12.00.00
    Dashboard version VMCLite_9.3.0.9237_RP2
    Voice feature enabled
    SIM Lock status Locked (Card Lock)
    Wrong codes entered 1
    and a question, what is the flash code for?
    Thank U in advance!
  11. #1196
    Quote Originally Posted by spaceman666 View Post
    Hello there!
    modem K3520
    Model Huawei K3520
    Thank U in advance!
    Flash: 41223911
    Unlock: 65021738
    Answers to all possible questions already in this thread!
  12. #1197
    Default Help Huawei E1550
    Please help.
    Huawei
    Model : E1550
    IMEI : 358811036250528
    Firmware : 11.608.09.01.21
    Hardware: CD6ATCPU
  13. #1198
    Thumbs up Thanksalot!
    Flash: 41223911
    Unlock: 65021738
    Thank you! Thank you! Thank you! Thank you! Thank you!
    It works perfectly, using it now!
  14. #1199
    Default :)
    Hi could you help unlock my modem?
    model:E122
    IMEI:356882030393137
    THANKS IN ADVANCE!
  15. #1200
    Thanks to you and also to MKAlex. I think my E180 is unlocked now.
    DC_unlocker displays the following:
    Found modem : E180
    Model : Huawei E180/E180G
    IMEI : 356185036390408
    Firmware : 11.126.04.00.157
    Dashboard version : Netvigator_3.0.1.36_Mac11.303.08.03.157
    Serial NR. : DJ4CAA19B1xxxxxx
    Voice feature : disabled
    SIM Lock status : unlocked
    Wrong codes entered : 0 (unlock attempts left : 10)
    HSPA Connection Manager does not ask for unlock code with an unacceptable SIM.
    I guess I unlocked the SIM lock using Hyperterminal yesterday, only that my input did not get echoed back and I got a response something like Error 13 (can't remember).
