Results 1 to 8 of 8
    Apr 2017
    Default Abs Clio IV 95640
    Can someone help me change the km on ABS clio 4
    old 151000
    new 130000
    eprom 95640
    xm3n's Avatar
    Jan 2017
    Here..............
    Sharing Is Caring....
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Quote Originally Posted by RPAuto View Post
    old 151000
    new 130000
    eprom 95640
    Orginal have 154100 ? if orginal have 154100 that solution u will get 297772.
    Nothing will remain in this World , Everything will come to END!
    THINK POSITIVE NOTHING IS IMPOSSIBLE
    Please do not spam by PM asking for help. Use forum, that is why we are here.
    Apr 2017
    you're right the car has 154100 i was to confirm to the engine ecu
    this car had already been made by obd
    but stayed with on-board computer crazy.
    Apr 2017
    someone can help me with file?
    xm3n's Avatar
    Jan 2017
    If that Solution Dosent Work
    Try this
    If your Original km - 154100 km
    Then here is the edited file this is 100% perfect
    next time you should update with correct information ...
  7. The Following User Says Thank You to xm3n For This Useful Post:
    RPAuto (21st November, 2017)
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    above file have 129926, if u need exatly here is the file for u..................
  9. The Following 3 Users Say Thank You to zckariya70 For This Useful Post:
    clusters (21st November, 2017), Johnner (21st November, 2017), RPAuto (21st November, 2017)
  10. #8
    Team dz's Avatar
    Apr 2017
    ALGERIA
    HERE THIS SOFTWARE ABS DUMP TOOL
  11. The Following 9 Users Say Thank You to Team dz For This Useful Post:
    Johnner (21st November, 2017), m_yura (21st November, 2017), n599fbm (13th April, 2018), NStuning (15th September, 2019), pps (7th February, 2018), RPAuto (21st November, 2017), stefaudio (21st November, 2017), xm3n (21st November, 2017), zckariya70 (21st November, 2017)
