Results 1 to 8 of 8
    In EEP
    Default Skoda Octavia 2 facelift 2009 cluster repair
    Hi kineed help or kick for repair VDO cluster with nec24c32 . problem with led lights if turn key on blinker indicator lights are glowing permanently or together with other indicators and illumination on fuel gauge and temperatur not work. thanks for you help
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by vasa View Post
    i have to same problem in 3 cars.
    my solution is change dash
  3. The Following User Says Thank You to rola1971 For This Useful Post:
    yugo45 (24th November, 2017)
    In EEP
    Hi problem solved if ewerbody will kick ......check others led :-)
  5. The Following User Says Thank You to vasa For This Useful Post:
    Danielsach (1st December, 2020)
  6. #4
    uk
    please can you explain little clearer how to fix..
    Ireland
    Is there a working fix for these custers ?
  8. #6
    Ireland
    Quote Originally Posted by frontpager View Post
    PM's welcome.
  9. #7
    Romania
    Mi,have same problem with Oktavia 2 FL cluster,anyone have a solution for fix this?Thank's!
  10. #8
    Germany
    This is a common problem on this clusters. Reason always is a kind of short circiut in other LED. Problem is to find out, what led it is, because this does not mean, that this other LED is not working (illuminating) anymore. Easiest way is to diassemble the cluster and connect only pcb without display and housing. I always lift some LEDīs on one side and test. So you can find the problem-LED rather fast. In this situation it is good to have some junk clusters to replace LEDīs.
    Greets MR...
  11. The Following 2 Users Say Thank You to brobble For This Useful Post:
    chiorbeq (28th March, 2022), jarek88 (19th June, 2023)
