Results 1 to 4 of 4
    Nov 2012
    Default ECU MCP Gearbox Citroen SIM82 problem
    Hi guys,
    i have an gearbox MCP ECU defective. (Cant do calibration)
    References: Siemens S118475101F
    HW: 9640922780
    SW: 9654953980
    I want to know if i can take an used ECU (Same hardware but not SW and Siemens Reference) and make virgin or can adapt with Lexia used car without modification.
    Thank you very much
    Mar 2012
    If HW is the same, you can simply change flash inside (29f400)
  3. The Following User Says Thank You to gsmrepair For This Useful Post:
    chiptuner8 (19th December, 2017)
    Nov 2012
    Quote Originally Posted by gsmrepair View Post
    Thank you friend. You try that before?
    Mar 2012
    Sorry for the delay. yes i did.
