Results 1 to 2 of 2
    Dec 2017
    Default Iveco Daily 3 2003 dashboard instrument cluster disassembly how to
    hello everyone, can someone share some light on how to disassemble the cluster intrument for and iveco daily 2.8 from 2004. need to check/change the oil pressure led (it stopped working and the engine sensor & wiring is ok)
    notice that is stuck together by some plastic clips.DSC_0136.JPGDSC_0137.JPG
    any help is greatly appreciated!
    Dec 2017
    i had to tear off the face off the cluster is glued as you can see in the prev pic and damage most of the plastic clems which hold the board along with the screws. now you can remove the torx srewsDSC_0150.JPG
