Results 1 to 12 of 12
Thread: dbox2 pin code
    Aug 2008
    Default dbox2 pin code
    hi all..does anyone know how to either reset or remove the pin code from the dbox menu's, im trying to upload a new image but when i click on services to update it asks for a pin number which i do not know, does anyone know what the original pin should be??
    thanks for any help offered.
    im new to this furum so may take me a while to repond to answers.
    Jul 2008
    try entering 1234
    Aug 2008
    Question nokia dbox2 pin code needed
    iv tried all the usual easy stuff...9999, 1234,4321,1111 etc..etc.
    cheers
    V.I.P. Member gizmo.1484's Avatar
    Apr 2008
    WestYorkshire
    Quote Originally Posted by chris heys View Post
    hi all..does anyone know how to either reset or remove the pin code from the box menu's, im trying to upload a new image but when i click on services to update it asks for a pin number which i do not know, does anyone know what the original pin should be??
    in new to this furum so may take me a while to respond to answers.
    Press DBox button then go down to service settings press that then go down to parental controls press that know you should have a option to change pin code.
    Aug 2008
    thats the problem!!..i dont know the code so cant get into the services menu..
    Apr 2008
    WestYorkshire
    Post How to bypass the pin code on Sagem dbox
    Hello Mate
    There are 2 methods to find the pin code on a dbox2
    either ftp into var/tuxbox/config and view neutrino.conf, look for parentallock_pincode=####
    the #### is the pin code.
    If you want you can do it from the dbox
    Choose Tuxbox Commander
    var ok
    tuxbox ok
    config ok
    scroll down to neutrino.conf ok
    then scroll down to the line, it is in alphabetical order.
    home
    home
    Hope this helps m8
    Jun 2008
    Quote Originally Posted by chrisheys View Post
    try 0000 if this don't work then look in the var/tuxbox/config in this folder there will be a file called neutrino.conf it'll be in there prob called parentallock=****
    cheers
    plasterer's Avatar
    Jun 2008
    Mersyside
    Quote Originally Posted by gizmo.1484 View Post
    Hello Mate
    var ok
    tuxbox ok
    config ok
    home
    home
    Hope this helps m8
    That looks Familiar.................LOL.....Paul
    PAUL
    Aug 2008
    Hello Mate
    var ok
    tuxbox ok
    config ok
    home
    home
    Hope this helps m8
    hi..thanks for the info but i have no idea how to do these things, im not a whizz with this sort of thing unfortunatly so have no idea how to go about ftp into files or where to find tuxbox commander.
    cheers
    Member bobsylas's Avatar
    Jun 2008
    what image is it mate ?
    maybe we can find out that way
    Apr 2008
    WestYorkshire
    cheers
    You will find the tuxbox commander by pressing the blue button on your remote then you will see a screan with the dbox files. Then go to var press ok then go to tuxbox press ok then go to config press ok scroll down to neutrino.conf press ok then scroll down to the line,of the password then change to your then press home it will ask you if you want to save press yes. Now your password will be changed.
    Aug 2008
    Quote Originally Posted by bobsylas View Post
    hurray ...cracked it...cheers to all who helped..just did a bit of searching on how to ftp into the box and followed a few instructions from web and on here and managed to do it..new blade quad image being installed as i type.
    thanks again for all your help...ur all the best
