Results 1 to 8 of 8
    Oct 2017
    Default Remote key no longer working after flash with NCS Expert (Mini Cooper S R53)
    SOLVED:
    Turns out I had to "reflash" the modules with NCS Expert with v38 daten in Expertmode, thus setting BC1 back to stock. After that, the sync trick worked (4 times ingnition, etc.).
    The issue was caused by bad daten (probably?).
    Hi all,
    I've been playing around with NCS Expert on my R53 Mini Cooper S this weekend, so far so good.
    I tryied some functions, some did work, some didn't. At the end of the day, I got out of the car, and now for some unknown reason the remote lock/unlock doesn't work anymore!
    I tought I messed up something with NCS Expert, so I loaded the default VO values of my car (there are tons of guides for this "back to stock" flash).
    This worked (settings reverted to stock) but still the keyfob doesn't work!
    I checked with ISTA-d and DISv44 the Car/Key Memory and the key is still there, in the first slot, exactly where I coded it some weeks ago); other slots are empty, that's ok.
    I don't really know what to do, the dealer is quite far from my location and I can't do such a trip because of my job.
    Below is the NCS Expert config, wich is the stock (seem so, it has been generated by NCS with an empty file) of my car, so it can be checked by some of you that are way smarter than me.
    Big thanks to anybody that will try to help me!
    FH_FAHRERTUER_TIPP_AUF aktiv
    FH_BEIFAHRERTUER_TIPP_AUF
    aktiv
    DWA
    nicht_aktiv
    SCHAERFEN/ENTSCHAERFEN
    schloss_und_fernbedienung
    PANIK_MODUS
    nicht_aktiv
    FUNK_INNENRAUMSCHUTZ
    aktiv
    QUIT_AKUST_SCHAERF
    nicht_aktiv
    QUIT_AKUST_ENTSCH
    nicht_aktiv
    QUIT_OPT_ENTSCH
    aktiv
    QUIT_OPT_SCHAERF
    nicht_aktiv
    NEIGUNGSGEBER
    aktiv
    ALARM_AKUSTISCH
    aktiv
    BEDIENSTELLE_BFT
    nicht_aktiv
    FH_ABSCHALTKRITERIUM
    wert_03
    FH_NACH_TUERE_AUF
    nicht_aktiv
    FUNKTION_CABRIO
    nicht_aktiv
    EINKLEMMSCH_REVERSIEREN
    nicht_aktiv
    ALARM_AKUSTISCH_LANG
    nicht_aktiv
    IB_BEI_KL.R_AUS
    aktiv_mit_kl.58
    KALTUEBERWACHUNG_NSL
    nicht_aktiv
    KALTUEBERWACHUNG_NSW
    aktiv
    SCHEINWERFERREINIGUNG
    nicht_aktiv
    CC_BREMSLICHT
    aktiv
    ALARM_OPT_ABBLENDLICHT
    nicht_aktiv
    ALARM_OPT_FERNLICHT
    nicht_aktiv
    ALARM_OPT_WARNBLINKER
    aktiv
    LEUCHTWEITENREG_AUTOM
    nicht_aktiv
    VERRIEGELN_AUT_AB_X_KM/H
    aktiv
    WISCHERINTERVALL
    wert_01
    ZV_SELEKTIV
    nicht_aktiv
    CLT_AKTIV_IM_CRASH_MODE
    nicht_aktiv
    CODIERUNG_ERFOLGT_1
    codierung_erfolgt
    ENTSICHERN_CENTERLOCK
    nicht_aktiv
    INNENLICHT_AN_MEHRFACH_ZV
    aktiv
    KOMFORTSCHLIESSUNG_FB
    nicht_aktiv
    STANDRUECKSCHALTUNG
    aktiv
    VERRIEGELN_XKM/H_SENDER_1
    aktiv
    VERRIEGELN_XKM/H_SENDER_2
    aktiv
    VERRIEGELN_XKM/H_SENDER_3
    aktiv
    VERRIEGELN_XKM/H_SENDER_4
    aktiv
    VERZUG_PANIK_MODUS_0.2_S
    wert_01
    VERRIEGELN_AUT_NACH_2_MIN
    aktiv
    VERRIEGELUNGSSCHWELLE
    16_km/h
    ABFRAGEZEIT_AHM
    wert_01
    ABSCHALTUNG_UNTERSPG
    wert_01
    ENTPRELLZAHL_FEHLERERK
    wert_01
    KALTUEBERWACHUNG_AL
    aktiv
    KALTUEBERWACHUNG_FL
    aktiv
    ABSTAND_HOLD_NORMAL_MODE
    wert_01
    HALB/VOLLSCHRITT
    vollschritt
    HYSTERESE_STARTBEDINGUNG
    wert_02
    KALTUEBERWACHUNG_BLK_HI
    nicht_aktiv
    KALTUEBERWACHUNG_BLK_VO
    nicht_aktiv
    SCHRITTABSTAND_GRENZE
    wert_01
    SCHRITTABSTAND_STARTPHASE
    kennlinie_01
    TEMPERATUR_GRENZE
    grad_-20
    ABS_MIN_STELLUNG_2
    wert_01
    GED_FL_ALS_DRL
    nicht_aktiv
    HEIMLEUCHTEN
    wert_02
    SCHRITTE_STELLUNG_0
    wert_01
    wert_02
    SCHRITTE_STELLUNG_1
    wert_03
    wert_06
    SCHRITTE_STELLUNG_2
    wert_06
    TAGFAHRLICHT_ECE
    nicht_aktiv
    U_POTI_STELLUNG_0
    wert_01
    U_POTI_STELLUNG_1
    wert_01
    U_POTI_STELLUNG_2
    wert_01
    BLS_PRUEFEN
    nicht_aktiv
    ABSENKUNG_10_KM/H
    wert_02
    ABTASTRATE_DYN
    wert_01
    ABTASTRATE_TREND
    wert_01
    ABWEICHUNG_TREND
    wert_01
    ANHEBUNG_175_KM/H
    wert_02
    ANZAHL_QUICK_RUNDEN
    wert_01
    AUSWERT_GRADIENT
    aktiv
    AUSWERT_PROP_ABWEICHUNG
    aktiv
    DAUER_DYN_NACHFUEHRUNG
    wert_01
    DEF_LWR_SENSOR_HI
    wert_01
    DIFFERENZ_MSP_DYN_STAT
    wert_01
    EPSILON_DELTA_A
    wert_02
    EPSILON_DELTA_AV
    wert_02
    GRADIENT_SCHLECHTWEG
    nicht_aktiv
    HOEHENWEG
    wert_01
    KALTUEBERWACHUNG_KZL
    aktiv
    KENNLINIE_LWR_SENSOR_HI
    wert_02
    KENNLINIE_LWR_SENSOR_VO
    wert_01
    LEUCHTWEITENREG_DYNAM
    nicht_aktiv
    LEUCHTWEITENREGELUNG
    aktiv
    LWR_NEIGUNG_KONSTANTE
    wert_02
    LWR_VORZEICHEN
    wert_01
    M_TELEGRAM
    nicht_aktiv
    MIN_STEIGUNG_VZ_WECHSEL
    wert_01
    MINDESTANZAHL_VZ_WECHSEL
    wert_01
    MITTELUNGSINTERV_DYN
    wert_01
    MITTELUNGSINTERV_TREND
    wert_01
    MITTELUNGSINTERV_VZ_WECHS
    wert_01
    NACHLAUF_SCHLECHTWEG
    wert_01
    OFFSET_LWR
    wert_02
    PWM_ANSTEUERUNG_KZL
    wert_01
    REFERENZL_MODE_TEIL1
    wert_01
    REFERENZL_MODE_TEIL2
    wert_01
    REFERENZL_SCHRITTABSTAND
    wert_01
    REFERENZL_SCHRITTANZAHL
    wert_01
    SAETT_TIMER_SCHLECHTWEG
    aktiv
    SCHW_GRAD_BESCHLEUNIGUNG
    wert_01
    wert_02
    SCHW_GRAD_BREMSEN
    wert_01
    wert_02
    SCHW_GRADIENT_SCHLECHTWEG
    wert_01
    SCHW_PROP_ABWEICHUNG
    wert_01
    wert_02
    SCHW_TREND
    wert_01
    SP_MOTOR_BEWERTEN
    aktiv
    SP_MOTOR_F_EINTRAG
    aktiv
    SP_MOTOR_STOP
    aktiv
    TREIBER_BEWERTEN
    aktiv
    TREIBER_F_EINTRAG
    aktiv
    VMAX_BESCHLEUNIGUNG
    wert_01
    VMAX_BREMSEN
    wert_01
    VMIN_BESCHLEUNIGUNG
    wert_01
    VMIN_BREMSEN
    wert_01
    WARMUEBERWACHUNG_KZL
    aktiv
    ZEIT_KALT_PULSE
    wert_01
    ZEIT_KALT_PULSE_QUICK
    wert_01
    ZEIT_KALT_RUNDEN
    wert_01
    ZYKLUS_KALT_RUNDEN_QUICK
    wert_01
    AC_AUTO
    aktiv
    AC_BASIC
    nicht_aktiv
    AUXILIARY_LAMP_ENABLE
    nicht_aktiv
    BOOT_RELEASE_ENABLE
    aktiv
    CLUTCH_OFF
    wert_01
    CLUTCH_ON
    wert_01
    DAYLIGHT_RUN_POWER
    wert_01
    DEFAULT_EXT_AMBIENT_TEMP
    nicht_aktiv
    DIPPED_BEAM_NAS
    nicht_aktiv
    ENTRIEGELN_B_MOTOR_STOP
    aktiv
    FOG_DISABLE_WITH_TRAILER
    aktiv
    FRONT_FOG_NAS
    nicht_aktiv
    HALTEN_FB_OEFFNEN_TASTE
    ohne_funktion
    HFS
    nicht_aktiv
    HFS_HIGH_TEMP_TIME
    wert_01
    HFS_LOW_TEMP_TIME
    wert_01
    HR_HIGH_BAT_THRESHOLD
    wert_01
    HRW_HIGH_TEMP_TIME
    wert_01
    HRW_LOW_BAT_THRESHOLD
    wert_01
    HRW_LOW_TEMP_TIME
    wert_01
    INDICATE_DURING_HAZARD
    aktiv
    KEY_DISARM
    aktiv
    KOMFORTOEFFNUNG_SCHLOSS
    nicht_aktiv
    MAN_WISCHEN_IM_WASCHPROG
    aktiv
    NO_SOFT_ON_OFF
    nicht_aktiv
    PARKING_LIGHTS
    nicht_aktiv
    POWER_WASH_OFF_TIME
    wert_01
    POWER_WASH_ON_TIME
    wert_01
    REAR_WIPER_CONTINUOUS
    nicht_aktiv
    REMOTE_CONTROL
    aktiv
    SENSOR_REGEN
    nicht_aktiv
    WINDOW_AUTO_UP_DRIVER
    aktiv
    WINDOW_AUTO_UP_PASS
    nicht_aktiv
    WINDOW_INCH_AUTO
    aktiv
    WINDOW_SUNROOF
    aktiv
    WIPER_BOOT_INHIBIT
    nicht_aktiv
    WIPER_CAM_DELAY
    wert_01
    WIPER_NO_PROG_REAR_WASH
    nicht_aktiv
    WIPER_REAR_CAM_DELAY
    wert_01
    WIPER_WASHER_START_TIME
    wert_01
    WISCHER_GESCHW_ABHAENGIG
    aktiv
    FRONT_FOG_ENABLE
    aktiv
    HEADLAMP_LEVEL_TYPE
    lwr_intern
    INERTIA_SW_FITTED
    nicht_aktiv
    REAR_FOG_ENABLE
    aktiv
    ABSCHALTUNG_VERBRAUCHER
    aktiv
    AL_AUS_BEI_KL_50
    aktiv
    ANHAENGERMODUL_PWM_WERT
    wert_01
    ANLAUFSTROMBEGRENZ_MEMO
    nicht_aktiv
    ANSTEUERZEIT_MOTOR_HK
    wert_01
    ANSTEUERZEIT_ZV_AGGREGATE
    plus_0ms
    ANZAHL_NACHWISCHZYKLEN
    4
    ANZAHL_SPRITZIMPULSE
    ANZAHL_WASCHBET_ZUR_SRA
    7
    AUSSENTEMP_SENSOR
    aktiv
    BEDIENSTELLE_FT
    aktiv
    BETR_STD_NICHT_LOESCHEN
    aktiv
    BETRMODI_DEAKT_KL15_EIN
    nicht_aktiv
    BLINKIMPULS_WARNBLK
    nicht_aktiv
    BLOCKIERSCHUTZ_AKT_XXS
    wert_01
    BLOCKIERSCHUTZ_HI_AKT_XXS
    wert_01
    CABRIO_FH_VO_ZEIT_AUF
    1000ms
    CABRIO_FH_VO_ZUERST_AUF
    aktiv
    CABRIO_FH_VO_ZUERST_ZU
    nicht_aktiv
    CENT_LOCK_MGL_VO_TUER_AUF
    nicht_aktiv
    CODIERUNG_ERFOLGT_0
    codierung_erfolgt
    CODIERUNG_ERFOLGT_4
    codierung_erfolgt
    CODIERUNG_ERFOLGT_5
    codierung_erfolgt
    CODIERUNG_ERFOLGT_6
    codierung_erfolgt
    CODIERUNG_ERFOLGT_7
    codierung_erfolgt
    DIFFERENZ_ANLAUF_BLOCK
    wert_01
    DRITTE_TASTE_SENDER
    wert_01
    DWA_HEKKLEPPENKONTAKT
    aktiv
    EINKLEMMSCH_VORNE
    nicht_aktiv
    EINSTEIGHILFE
    nicht_aktiv
    EINSTIEG_FH_ZU_VER_SPERRE
    nicht_aktiv
    EKS_GEDRUECKT/OFFEN
    wert_01
    EKS_OFFEN/UNTERBRECHUNG
    wert_01
    EKS_REVERSIERZEIT_ZUS
    wert_01
    ENTR_HKL_MGL_WENN_VER
    nicht_aktiv
    FE_MODE_JEDOCH_MIT_FB
    nicht_aktiv
    FERNBEDIENUNG_1
    zv_selektiv
    FERNBEDIENUNG_2
    nicht_aktiv
    FERNBEDIENUNG_3
    nicht_aktiv
    FERNBEDIENUNG_4
    nicht_aktiv
    FH_ABSCHALTEN_BLOCK_AUF
    wert_01
    FH_ABSCHALTEN_BLOCK_ZU
    wert_01
    FH_ANHEBEN_TRANSPORTMODE
    aktiv
    FH_BLOCKABSCHALT_TUER_AUF
    wert_01
    FH_HINTEN_TIPP_AUF
    aktiv
    FH_HINTEN_TIPP_ZU
    nicht_aktiv
    FH_INIT_TRANSPORTMODE
    nicht_aktiv
    FH_SPEICHERN_TRANSPORTMOD
    aktiv
    FH_TIMEOUT
    8sec
    FL_AUS_BEI_KL_50
    aktiv
    FRISCHLUFT_PARKPOSTITION
    aktiv
    FZV_TIMEOUT
    wert_02
    HFS_ON_TIME_LOW_VOLTAGE
    wert_01
    HKL_SPERREN_BEI_ZS
    nicht_aktiv
    HRW_NUR_BEI_GESCHL_VERDEK
    nicht_aktiv
    HRW_ON_TIME_LOW_VOLTAGE
    wert_01
    HUB_VERZOEGERUNG_FH_VORN
    0ms
    IB_AUS_NACH_X_SEKUNDEN
    20s
    IB_BEI_KL.R_AUS_OHNE_58G
    ohne_bedingung
    IB_EIN_16MIN_WENN_STANDLI
    nicht_aktiv
    IB_EIN_BEI_HKK/HSK
    aktiv
    IB_EIN_N_KL_58G_MAX_1MIN
    zwei_minuten
    IB_EIN_SCHLOSS_ENTRIEGELN
    aktiv
    KALTUEBERW_AUS_BEI_KL_50
    aktiv
    KALTUEBERWACHUNG_BL
    nicht_aktiv
    KALTUEBERWACHUNG_BL_MI
    nicht_aktiv
    KALTUEBERWACHUNG_SL_H
    aktiv
    KALTUEBERWACHUNG_SL_V_I
    aktiv
    KALTUEBERWACHUNG_ZSW
    nicht_aktiv
    KEIN_HECKWISCHER
    mit_heckwischer
    KOMFOEFFNEN_SPERRE_KEY_IN
    aktiv
    KOMFORTOEFFNEN_FB_O_FH_HI
    nicht_aktiv
    KOMFORTOEFFNEN_FB_O_SHD
    nicht_aktiv
    KOMFORTOEFFNUNG_CLT
    nicht_aktiv
    KOMFORTSCHLIE_FB_O_FH_HI
    nicht_aktiv
    KOMFORTSCHLIE_FB_OHNE_SHD
    nicht_aktiv
    KOMFORTSCHLIESUNG_SCHLOSS
    aktiv
    KRB_WIE_VA/HKK_STATT_IB
    nicht_aktiv
    LAENDERVARIANTE_ECE
    aktiv
    LAENDERVARIANTE_US
    nicht_aktiv
    MAUT_N_ABBRECH_N_TUER_AUF
    nicht_aktiv
    MIN_PWM_TASTVERHAELTNIS
    wert_01
    MIT_AHM
    aktiv
    MIT_MFL
    nicht_aktiv
    MIT_OPT_ALARM
    aktiv
    MIT_WISCHER_SERVICEPOS
    nicht_aktiv
    N_VER_B_ERN_GESCHW_SCHWEL
    nicht_aktiv
    NSW_AUS_BEI_KL_50
    aktiv
    OFFENE_FENSTER
    nicht_aktiv
    OHNE_HRW
    nicht_aktiv
    OHNE_INRS_BESTAETIGUNG
    ohne_bestaetigung
    OHNE_SCHEIBENABSENKUNG
    mit_absenkung
    POTISTELLUNG_IN_77H
    wert_01
    PWM_ANSTEUERUNG_AL
    wert_03
    PWM_ANSTEUERUNG_BL
    wert_01
    PWM_ANSTEUERUNG_BLK_HI
    wert_01
    PWM_ANSTEUERUNG_BLK_VORN
    wert_01
    PWM_ANSTEUERUNG_FERNLICHT
    wert_01
    PWM_ANSTEUERUNG_IL
    wert_01
    PWM_ANSTEUERUNG_NSL
    wert_01
    PWM_ANSTEUERUNG_SL_H
    wert_01
    PWM_ANSTEUERUNG_SL_V_I
    wert_01
    PWM_ANSTEUERUNG_VA
    wert_01
    QUIT_AKUST_SCHAERF_KLAPPE
    nicht_aktiv
    QUIT_OPT_ANZAHL_ENTSICHRN
    QUIT_OPT_ANZAHL_SICHERN
    QUIT_OPT_SCHAERF_KLAPPE
    aktiv
    QUITIMP_SICHERN/ENTSICHER
    aktiv
    ROVER_FZV_STATT_BMW
    bmw_fzv
    SCHEIBE_ABSENKZEIT
    wert_01
    SCHEIBENABSENK_OHNE_EKS
    ohne_eks
    SCHWELLE_GEBLAESESENSOR
    wert_01
    SCHWELLE_MERHK_KS
    wert_01
    SCHWELLE_MERHK_OL
    wert_01
    SENSOR_REGEN_N_STUFE2
    stufe_2
    TAUSCH_AUSGANG_NSL_NSW
    nicht_aktiv
    TRA_MODE_JEDOCH_MIT_FB
    nicht_aktiv
    UEBERSPGSABSCHALTUN_AL/FL
    aktiv
    UMLUFT_PARKPOSTITION
    nicht_aktiv
    VA1/VA2_AUS_NACH_X_MIN
    16_min
    VERL_ALARMZEI_WAEHR_ALARM
    nicht_aktiv
    VERZ_FRWISCHER_N_WASCHANF
    wert_01
    VERZ_HKWISCHER_N_WASCHANF
    wert_01
    VERZOEGERUNG_S56A_D_AUS
    wert_01
    VERZOEGERUNG_SHD_KOE
    sofort
    VERZOEGERUNG_SHD_KS
    sofort
    WARMUEBERWACHUNG_AL
    aktiv
    WARMUEBERWACHUNG_BL
    aktiv
    WARMUEBERWACHUNG_BL_MI
    aktiv
    WARMUEBERWACHUNG_BLK_HI
    aktiv
    WARMUEBERWACHUNG_BLK_VO
    aktiv
    WARMUEBERWACHUNG_FL
    aktiv
    WARMUEBERWACHUNG_NSL
    aktiv
    WARMUEBERWACHUNG_NSW
    aktiv
    WARMUEBERWACHUNG_SL_H
    aktiv
    WARMUEBERWACHUNG_SL_V_I
    aktiv
    WARMUEBERWACHUNG_ZSW
    nicht_aktiv
    WE_MODE_JEDOCH_MIT_FB
    nicht_aktiv
    WISCHER_RUECK_GESCHW
    wert_01
    WISCHER_VOLLEND_KLR_AUS
    keine_vollendung
    WISCHERINTERVALL_HECK
    wert_01
    XENON_TEST
    nicht_aktiv
    XENON_TIME
    wert_01
    XENON_TIMEOUT
    wert_01
    ZEIT_TUER/SCHLIESSZEIT
    wert_01
    ZEIT_WASCH_M/O_HKWISCHER
    wert_01
    ZSW_AUS_BEI_KL_50
    aktiv
    KS_ABSCHALTUNG_AL
    nicht_aktiv
    KS_ABSCHALTUNG_BL
    aktiv
    KS_ABSCHALTUNG_BL_MI
    nicht_aktiv
    KS_ABSCHALTUNG_BLK_HI
    aktiv
    KS_ABSCHALTUNG_BLK_VO
    aktiv
    KS_ABSCHALTUNG_FL
    nicht_aktiv
    KS_ABSCHALTUNG_IB
    aktiv
    KS_ABSCHALTUNG_KRB
    nicht_aktiv
    KS_ABSCHALTUNG_KZL
    nicht_aktiv
    KS_ABSCHALTUNG_NSL
    aktiv
    KS_ABSCHALTUNG_NSW
    nicht_aktiv
    KS_ABSCHALTUNG_SL_H
    nicht_aktiv
    KS_ABSCHALTUNG_SL_I
    nicht_aktiv
    KS_ABSCHALTUNG_VA
    aktiv
    KS_ABSCHALTUNG_ZSW
    nicht_aktiv
    ALARM_MUW_SENSOR
    nicht_aktiv
    CABRIO_FH_KOMP_AUF_MIT_FB
    nicht_aktiv
    CABRIO_FH_NICHT_ZU_MIT_FB
    nicht_aktiv
    KALTUEBERWACHUNG_BL_MI_2
    nicht_aktiv
    KALTUEBERWACHUNG_IB2
    nicht_aktiv
    LWR_POS2
    wert_03
    LWR_POSR
    wert_03
    MIT_AUSSTIEGSLEUCHTE
    nicht_aktiv
    MIT_NSL_RECHTS
    nicht_aktiv
    PWM_ANSTEUERUNG_IB2
    wert_01
    WARM_WITH_OL_BTS716
    nicht_aktiv
    WARMUEBERWACHUNG_IB2
    nicht_aktiv
    ZENTRAL_FH_SCHALTER
    nicht_aktiv
    ZENTRAL_FH_SCHALTER_VERZ
    wert_02
    BLS_POLL_TIME
    wert_02
    ZENTRAL_FH_SCHALTER_MAUT
    nicht_aktiv
    FLC_FAILSAFE
    nicht_aktiv
    FLC_OHNE_RLS
    nicht_aktiv
    MIT_FLC
    nicht_aktiv
    MIT_FLC_SCHALTER
    nicht_aktiv
    MIT_WWA
    aktiv
    WWA_MOTOR_AN_ZEITZELLE
    wert_01
    WWA_MOTOR_AUS_ZEITZELLE
    wert_01
    WWA_SENSOR_ABTASTUNG
    wert_02
    ANLIEFERKODIERUNG
    nicht_aktiv
    KALTUEB_AUS_BEI_SCG
    aktiv
    KOMFORT_OEFFNEN_VERZ
    wert_01
    wert_02
    KOMFORT_SCHLIESSEN_VERZ
    wert_01
    MAUT_NUR_BEI_MOTOR_AN
    nicht_aktiv
    TILT_SIRENE
    aktiv
    TM_ENTR_HECKKLAPPE
    aktiv
    WWA_LED_KL15_DAUER
    wert_01
    WWA_LED_MOT_DAUER
    wert_01
    WWA_LED_TAKT_AUS
    wert_01
    WWA_LED_TAKT_EIN
    wert_01
    WWA_LED_TRIG_DAUER
    nicht_aktiv
    WWA_LED_WASCH_DAUER
    wert_01
    TM_FOLLOW_ME_HOME
    nicht_aktiv
    TM_POSLIGHT
    nicht_aktiv
    AUTOM_ER_KEY_OFF
    nicht_aktiv
    EXT_BEREICH_KURZHUB
    wert_01
    KURZHUB_KOMPL_ABSENKZEIT
    aktiv
    MAXWERT_FH_POS_HB
    wert_01
    MAXWERT_FH_POS_LB
    wert_01
    bram380's Avatar
    Indonesia +628153111774
    It is FRM or CAS module?
    Upload man or trc file
    Fallen's Avatar
    If you still have the bar code from the remote, try and program it back in.
    Oct 2017
    Quote Originally Posted by bram380 View Post
    in NCS I had only 2 options, KMB and EWS (should be the old CAS?) and I used EWS.
    I'll re-read the ECU and upload everything at lunch time
    Quote Originally Posted by Fallen View Post
    I tried this too, both with DIS and ISTA-d:
    - overwrite the 1 key
    - delete the 1 key and recode it again
    - code the key in another position (2 and 3, none worked)
    Right now I coded it back to the first position, as it was. I know that the "matching" codes are correct because it used to work until the NCS Expert mess.
    I guess it has something to do with the "comfort opening" or something like that.
    Aren't them supposed to reset when I default the settings with and empty FSW_PSW.MAN file?
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    One of those sayings come to mind ...if it an't broke, don't fix it
    i find these cars can be a nightmare esp with low batteries. Guess u could try a new key - see if works
    Oct 2017
    Quote Originally Posted by obdsystems View Post
    you are definitely right. shame on me for touching those stuff. this is really drivig me nuts
    for those asking, here's the trace file
    BREMSLICHTSCHALTER	aktiv
    SIDEBAG_FOND_LINKS_1
    	nicht_aktiv
    SIDEBAG_FOND_RECHTS_1
    	nicht_aktiv
    SIDEBAG_FOND_LINKS_2
    	nicht_aktiv
    SIDEBAG_FOND_RECHTS_2
    	nicht_aktiv
    ITS_RECHTS_1
    	nicht_aktiv
    ITS_LINKS_1
    	nicht_aktiv
    ITS_RECHTS_2
    	nicht_aktiv
    ITS_LINKS_2
    	nicht_aktiv
    GURTSCHLOSS_STROMSS_1
    	nicht_aktiv
    GURTSCHLOSS_STROMSS_2
    	nicht_aktiv
    BPLUS_TRENNUNG1_1
    	nicht_aktiv
    BPLUS_TRENNUNG1_2
    	nicht_aktiv
    HWL_1
    	nicht_aktiv
    HWL_2
    	nicht_aktiv
    SBE2_1
    	nicht_aktiv
    SBE2_2
    	nicht_aktiv
    VERRIEGELN_SITZLEHNE_FA_1
    	nicht_aktiv
    VERRIEGELN_SITZLEHNE_BF_1
    	nicht_aktiv
    VERRIEGELN_SITZLEHNE_FA_2
    	nicht_aktiv
    VERRIEGELN_SITZLEHNE_BF_2
    	nicht_aktiv
    CRASHPARAMETER_0
    	r50
    MRSAPARAMETER_0
    	r50
    	aktiv
    	aktiv
    ZEIT_BIS_AUTOM_SPERREN
    	wert_01
    CODIERUNG_ERFOLGT
    	codiert
    K_ZAHL_TACHO
    	46463_imp/km
    K_ZAHL_TACHO_KOMPL
    	46463_imp/km
    TANK_SICHERHEITSFAKTOR
    	wert_01
    TANK_FILTER_KL15
    	wert_01
    TANK_SCHWELLE_RESERVE
    	8_l
    TANK_MITTLUNGSZEIT
    	wert_01
    TANK_BERUHIGUNGSZEIT
    	wert_01
    LWS5_KENNFELD_0
    	r50
    LWS5_KENNFELD_1
    	r50
    LWS5_KENNFELD_2
    	r50
    LWS5_KENNFELD_3
    	r50
    LWS5_KENNFELD_4
    	r50
    LWS5_KENNFELD_5
    	r50
    LWS5_KENNFELD_6
    	r50
    PRE_VLABS
    	aktiv
    EBV_LAMPE
    	aktiv
    SPERRDIFFERENZREGELUNG
    	nicht_aktiv
    TRAKTIONDIFFERENZREGELUNG
    	nicht_aktiv
    UNTERSTEUERUNGSALGORYTHM
    	nicht_aktiv
    VOLUMENDURCHFLUSSPARA
    	wert_01
    DYN_BREMS_UNTERSTUETZUNG
    	nicht_aktiv
    MAX_BREMS_UNTERSTUETZUNG
    	nicht_aktiv
    GETRIEBE
    	automatik
    PARK/NEUTRAL_EINGANG
    	aktiv
    LOGIK_HA_SPERRE
    	nicht_aktiv
    UEBERSTEUERN_MUE_0
    	wert_01
    UEBERSTEUERN_MUE_1
    	wert_01
    K_ZAHL_WEG
    	46463_imp/km
    K_ZAHL_WEG_KOMPL
    	46463_imp/km
    MOTOR_ART_ASC
    	wert_01
    MOTOR_ART
    	benziner
    MOTOR_ART_DSC
    	cooper
    DRUCKMODELL_HINTERACHSE
    	typ_0
    DRUCKMODELL_VORDERACHSE
    	typ_1
    REIFENDRUCKWARNSYSTEM
    	aktiv
    UNTERSTEUERSCHWELLE
    	wert_01
    UNTERSTEUERN_MUE_0
    	wert_01
    UNTERSTEUERN_MUE_1
    	wert_01
    SPRACHE
    	italienisch
    ZEIT_EINHEIT
    	24_stunden
    TEMPERATUR_EINHEIT
    	grad_c
    WEGSTRECKE_EINHEIT
    	km
    WEG_DURCHSCHNITT
    	km/h
    VERBRAUCH_D1
    	l/100km
    BC
    	nicht_aktiv
    KOMFORTSCHLIESSEN_VERDECK
    	aktiv
    DWA
    	nicht_aktiv
    BAUART_MK60
    	sport_chassis
    PANIK_MODUS
    	nicht_aktiv
    	aktiv
    QUIT_AKUST_SCHAERF
    	nicht_aktiv
    QUIT_AKUST_ENTSCH
    	nicht_aktiv
    QUIT_OPT_ENTSCH
    	aktiv
    QUIT_OPT_SCHAERF
    	nicht_aktiv
    NEIGUNGSGEBER
    	aktiv
    ALARM_AKUSTISCH
    	aktiv
    ABSCHALTDREHZAHL_ANLASSER
    	4_zylinder_benziner
    ZEITDAUER_BIS_ABSCHALTUNG
    	benziner
    SCHALT_KRITERIUM_EWS_3
    	4_zylinder_benziner
    EWS_3_SCHNITTSTELLE
    	aktiv
    ASC
    	aktiv
    BEDIENSTELLE_BFT
    	nicht_aktiv
    	wert_03
    FH_NACH_TUERE_AUF
    	nicht_aktiv
    FUNKTION_CABRIO
    	nicht_aktiv
    	nicht_aktiv
    	nicht_aktiv
    LL/RL
    	linkslinker
    LENKSEITE_1
    	linkslenker
    LENKSEITE_2
    	linkslenker
    GURTWARNUNG
    	ohne_gurtschlosskontakt
    TANK_SCHWELLE_AUF/AB
    	wert_01
    SIA_GRENZE_INSPEKTION
    	25.000_km
    SIA_GRENZE_ZEIT
    	716_tage
    SIA_LITER_GRENZE
    	1.6_cooper_auto
    IB_BEI_KL.R_AUS
    	aktiv_mit_kl.58
    GURTSTRAFFER_FAHRER_1
    	aktiv
    GURTSTRAFFER_FAHRER_2
    	aktiv
    GURTSTRAFFER_BEIFAHRER_1
    	aktiv
    GURTSTRAFFER_BEIFAHRER_2
    	aktiv
    AIRBAG_FAHRER_1
    	aktiv
    AIRBAG_FAHRER_2
    	aktiv
    FAHRERBAG_STUFE2_1
    	aktiv
    FAHRERBAG_STUFE2_2
    	aktiv
    AIRBAG_BEIFAHRER_1
    	aktiv
    AIRBAG_BEIFAHRER_2
    	aktiv
    BEIFAHRERBAG_STUFE2_1
    	aktiv
    BEIFAHRERBAG_STUFE2_2
    	aktiv
    GURTSCHLOSS_SPANNUNGSS_1
    	nicht_aktiv
    GURTSCHLOSS_SPANNUNGSS_2
    	nicht_aktiv
    GURTSCHLOSS_FAHRER_1
    	nicht_aktiv
    GURTSCHLOSS_FAHRER_2
    	nicht_aktiv
    GURTSCHLOSS_BEIFAHRER_1
    	nicht_aktiv
    GURTSCHLOSS_BEIFAHRER_2
    	nicht_aktiv
    ERKENNUNG_SITZBELEGUNG_1
    	nicht_aktiv
    ERKENNUNG_SITZBELEGUNG_2
    	nicht_aktiv
    AUSLOESEKRITERIUM_1
    	ece
    AUSLOESEKRITERIUM_2
    	ece
    SIDEBAG_LINKS_1
    	aktiv
    SIDEBAG_RECHTS_1
    	aktiv
    SIDEBAG_LINKS_2
    	aktiv
    SIDEBAG_RECHTS_2
    	aktiv
    B_SATELLIT_2
    	aktiv
    B_SATELLIT_1
    	aktiv
    CODIERANFORDERUNG_0
    	r50
    CODIERANFORDERUNG_1
    	r50
    BAUREIHE
    	r50
    CRASHPARAMETER_11
    	r50
    CRASHPARAMETER_12
    	r50
    CRASHPARAMETER_13
    	r50
    CRASHPARAMETER_14
    	r50
    CRASHPARAMETER_15
    	r50
    AUSSENTEMP_DELTA_K1
    	wert_01
    AUSSENTEMP_ZEITKONST_Z1
    	wert_01
    AUSSENTEMP_ZEITKONST_Z2
    	wert_01
    TANK_ANZEIGEWINKEL
    	kennlinie_01
    KUEHLMITTELTEMP_ANZEIGEWI
    	kennlinie_01
    LICHTWARNUNG
    	aktiv
    GETRIEBE_ART
    	automatik
    TANK_VORHALT_REICHW
    	wert_01
    WEG_EINHEIT
    	km
    	nicht_aktiv
    	aktiv
    	nicht_aktiv
    LETZTER_SERVICE
    	grundcode_var
    AKUSTIK_DWS
    	aktiv
    DWS
    	aktiv
    KUEHLMITTELTEMP_WERT
    	kennlinie_01
    ZUENDSCHLUESSEL_WARNUNG
    	nicht_aktiv
    AUSSENTEMP_WARN_AKUSTIK
    	aktiv
    CC_BREMSLICHT
    	aktiv
    	nicht_aktiv
    ALARM_OPT_FERNLICHT
    	nicht_aktiv
    	aktiv
    GLASDACH
    	aktiv
    	nicht_aktiv
    SCHIEBEHEBEDACH_TIPP_AUF
    	aktiv
    SCHIEBEHEBEDACH_TIPP_ZU
    	nicht_aktiv
    	aktiv
    WISCHERINTERVALL
    	wert_01
    ZV_SELEKTIV
    	nicht_aktiv
    	nicht_aktiv
    CODIERUNG_ERFOLGT_1
    	codierung_erfolgt
    	nicht_aktiv
    	aktiv
    	nicht_aktiv
    STANDRUECKSCHALTUNG
    	aktiv
    	aktiv
    	aktiv
    	aktiv
    	aktiv
    	wert_01
    	aktiv
    	16_km/h
    ABTASTFREQ_HINTERACHSE
    	wert_01
    ABTASTFREQ_VORDERACHSE
    	wert_01
    ACHSE_OBERGRENZE
    	wert_01
    ACHSE_UNTERGRENZE
    	wert_01
    AGRENZE
    	kennlinie_05
    ANSTEUERZEIT
    	kennlinie_02
    BGRENZE
    	wert_03
    DAUER_SCHNELLE_REGELUNG
    	wert_01
    DELTA_SCHNELL_LANGSAM
    	wert_01
    DELTAWERTE_HINTERACHSE
    	r50
    DELTAWERTE_VORDERACHSE
    	r50
    ERKENNUNG_BREMSLICHT
    	nicht_aktiv
    GRENZTEMPERATUR
    	wert_03
    INDEX_MOTORANSTEUERUNG
    	wert_02
    KL_30_UGRENZE
    	wert_01
    KURZSCHLUSS_ANZAHL
    	wert_01
    MAXIMALPOSITION
    	wert_02
    MIN_SCHRITT_DIFF
    	1_schritt
    MOTOR_KORREKTUR
    	r50
    MOTOR_OFFSET
    	wert_01
    MOTORDIAGNOSE
    	aktiv
    MOTORTABELLE_CHECKSUM
    	r50
    OPENLOAD_ANZAHL
    	wert_01
    REFERENZ_OFFSET
    	wert_01
    REFERENZFAHRT_PAUSE
    	wert_01
    REFERENZPOSITION
    	wert_02
    SENSOR_OBERGRENZE
    	wert_01
    SENSOR_UNTERGRENZE
    	wert_01
    STATUS_LESEN
    	aktiv
    STEIGUNG_HINTERACHSE
    	steigend
    STEIGUNG_VORDERACHSE
    	fallend
    TACHO_A_SPRUNG
    	wert_01
    V_BEREICHSFELD
    	kennlinie_01
    V_OFFSET
    	kennlinie_01
    WARTEZEIT_MOTOR
    	wert_01
    LIMIT
    	nicht_aktiv
    ABFRAGEZEIT_AHM
    	wert_01
    	wert_01
    	wert_01
    KALTUEBERWACHUNG_AL
    	aktiv
    KALTUEBERWACHUNG_FL
    	aktiv
    	wert_01
    GONG_1
    	wert_01
    HALB/VOLLSCHRITT
    	vollschritt
    	wert_02
    	nicht_aktiv
    	nicht_aktiv
    	wert_01
    	kennlinie_01
    TEMPERATUR_GRENZE
    	grad_-20
    ABS_MIN_STELLUNG_2
    	wert_01
    GED_FL_ALS_DRL
    	nicht_aktiv
    HEIMLEUCHTEN
    	wert_02
    SCHRITTE_STELLUNG_0
    	wert_02
    SCHRITTE_STELLUNG_1
    	wert_06
    SCHRITTE_STELLUNG_2
    	wert_06
    TAGFAHRLICHT_ECE
    	nicht_aktiv
    U_POTI_STELLUNG_0
    	wert_01
    U_POTI_STELLUNG_1
    	wert_01
    U_POTI_STELLUNG_2
    	wert_01
    BLS_PRUEFEN
    	nicht_aktiv
    ABSENKUNG_10_KM/H
    	wert_02
    ABTASTRATE_DYN
    	wert_01
    ABTASTRATE_TREND
    	wert_01
    ABWEICHUNG_TREND
    	wert_01
    ANHEBUNG_175_KM/H
    	wert_02
    ANZAHL_QUICK_RUNDEN
    	wert_01
    AUSWERT_GRADIENT
    	aktiv
    	aktiv
    	wert_01
    DEF_LWR_SENSOR_HI
    	wert_01
    	wert_01
    EPSILON_DELTA_A
    	wert_02
    EPSILON_DELTA_AV
    	wert_02
    	nicht_aktiv
    HOEHENWEG
    	wert_01
    	aktiv
    	wert_02
    	wert_01
    	nicht_aktiv
    	aktiv
    	wert_02
    LWR_VORZEICHEN
    	wert_01
    M_TELEGRAM
    	nicht_aktiv
    	wert_01
    	wert_01
    	wert_01
    	wert_01
    	wert_01
    	wert_01
    OFFSET_LWR
    	wert_02
    PWM_ANSTEUERUNG_KZL
    	wert_01
    	wert_01
    	wert_01
    	wert_01
    	wert_01
    	aktiv
    	wert_02
    SCHW_GRAD_BREMSEN
    	wert_02
    	wert_01
    	wert_02
    SCHW_TREND
    	wert_01
    SP_MOTOR_BEWERTEN
    	aktiv
    SP_MOTOR_F_EINTRAG
    	aktiv
    SP_MOTOR_STOP
    	aktiv
    TREIBER_BEWERTEN
    	aktiv
    TREIBER_F_EINTRAG
    	aktiv
    VMAX_BESCHLEUNIGUNG
    	wert_01
    VMAX_BREMSEN
    	wert_01
    VMIN_BESCHLEUNIGUNG
    	wert_01
    VMIN_BREMSEN
    	wert_01
    	aktiv
    ZEIT_KALT_PULSE
    	wert_01
    	wert_01
    ZEIT_KALT_RUNDEN
    	wert_01
    	wert_01
    MULTIFUNCTION_1
    	ece
    MULTIFUNCTION_2
    	ece
    WIDESCREEN_MODI
    	wert_00
    LAENDERVARIANTE_GT
    	ece
    SPEED_MAPS
    	wert_01
    SPEED_ROUTE_MAPS
    	wert_01
    USER_INPUT
    	wert_01
    AUTOMATISCHER_NOTRUF
    	nicht_aktiv
    BAUART
    	coupe
    TELEMATIK
    	nicht_aktiv
    ANZEIGE_ANKUNFTSZEIT
    	nicht_aktiv
    CRASHPARAMETER_MRS4_0
    	r50
    CRASHPARAMETER_MRS4_01
    	r50
    CRASHPARAMETER_MRS4_02
    	r50
    CRASHPARAMETER_MRS4_03
    	r50
    CRASHPARAMETER_MRS4_04
    	r50
    CRASHPARAMETER_MRS4_05
    	r50
    CRASHPARAMETER_MRS4_06
    	r50
    CRASHPARAMETER_MRS4_07
    	r50
    CRASHPARAMETER_MRS4_08
    	r50
    CRASHPARAMETER_MRS4_09
    	r50
    CRASHPARAMETER_MRS4_0A
    	r50
    CRASHPARAMETER_MRS4_0B
    	r50
    CRASHPARAMETER_MRS4_0C
    	r50
    CRASHPARAMETER_MRS4_0D
    	r50
    CRASHPARAMETER_MRS4_0E
    	r50
    CRASHPARAMETER_MRS4_0F
    	r50
    CRASHPARAMETER_MRS4_10
    	r50
    CRASHPARAMETER_MRS4_11
    	r50
    CRASHPARAMETER_MRS4_12
    	r50
    CRASHPARAMETER_MRS4_13
    	r50
    CRASHPARAMETER_MRS4_14
    	r50
    ITS_FRONTCRASH_1
    	nicht_aktiv
    ITS_FRONTCRASH_2
    	nicht_aktiv
    MRSAPARAMETER_01
    	r50
    MRSAPARAMETER_02
    	r50
    MRSAPARAMETER_03
    	r50
    MRSAPARAMETER_04
    	r50
    MRSAPARAMETER_05
    	r50
    MRSAPARAMETER_06
    	r50
    SBE1_STATUS_VERZ_1
    	nicht_aktiv
    SBE1_STATUS_VERZ_2
    	nicht_aktiv
    K_BUS_FREI_OHNE
    	nicht_aktiv
    ANZEIGE_FUEHRENDER_NULLEN
    	aktiv
    KALIBRIERUNG_TACHO
    	wert_01
    LCD_DIMMUNG_MAX
    	wert_01
    LCD_DIMMUNG_MIN_NACHT
    	wert_01
    LCD_DIMMUNG_MIN_TAG
    	wert_01
    REMOTE_KOMBI
    	dzm
    AC_AUTO
    	aktiv
    AC_BASIC
    	nicht_aktiv
    AC_POLUTION
    	aktiv
    ALARM_INDICATION
    	aktiv
    AUX_OFF_TIME
    	r50
    	nicht_aktiv
    BOOT_RELEASE_ENABLE
    	aktiv
    CAT1
    	nicht_aktiv
    CLUTCH_OFF
    	wert_01
    CLUTCH_ON
    	wert_01
    DAYLIGHT_RUN_POWER
    	wert_01
    	nicht_aktiv
    DIPPED_BEAM_NAS
    	nicht_aktiv
    DISABLE_FRESH_PARK
    	nicht_aktiv
    DISABLE_RECIRC_PARK
    	nicht_aktiv
    DO_MISLOCK_ON_ALL_RF
    	nicht_aktiv
    EEROM_STATUS
    	r50
    	aktiv
    	aktiv
    FRONT_FOG_NAS
    	nicht_aktiv
    	ohne_funktion
    HEADLAMP_LEVEL_POSITION1
    	wert_01
    HEADLAMP_LEVEL_POSITION2
    	wert_01
    HEADLAMP_LEVEL_POSITION3
    	wert_01
    HFS
    	nicht_aktiv
    HFS_HIGH_TEMP_TIME
    	wert_01
    HFS_LOW_TEMP_TIME
    	wert_01
    HFS_OFF_TIME
    	r50
    	wert_01
    HRW_HIGH_TEMP_TIME
    	wert_01
    	wert_01
    HRW_LOW_TEMP_TIME
    	wert_01
    HRW_OFF_TIME
    	r50
    	aktiv
    KEY_DISARM
    	aktiv
    KEYINTERLOCK_AUTO
    	auto
    KEYINTERLOCK_ENABLE
    	nicht_aktiv
    	nicht_aktiv
    LAMP_WITH_AUX_OFF
    	aktiv
    LAMP_WITH_AUX_SIDE
    	nicht_aktiv
    LAZY_LOCK_WITH_KEY
    	aktiv
    LIGHTS_ON_WITH_WIPERS
    	nicht_aktiv
    LOCK_DIRECT_SUPERLOCK
    	aktiv
    LOCK_DOUBLE_SUPERLOCK
    	nicht_aktiv
    	aktiv
    MANUFACTURING_MODE
    	nicht_aktiv
    MAX_ALARM_EVENTS
    	r50
    MAX_ON_LEVEL
    	r50
    NO_MAP_WITH_PERM_OFF
    	nicht_aktiv
    NO_SOFT_ON_OFF
    	nicht_aktiv
    NORMAL_MODE
    	aktiv
    PARKING_LIGHTS
    	nicht_aktiv
    POWER_WASH_MIN_OFF_TIME
    	r50
    POWER_WASH_OFF_TIME
    	wert_01
    POWER_WASH_ON_TIME
    	wert_01
    RAMP_DOWN_INCREMENT
    	r50
    RAMP_UP_INCREMENT
    	r50
    	nicht_aktiv
    REF_POINT_STEPPER_MOTORS
    	r50
    REMOTE_CONTROL
    	aktiv
    REMOTE_DIRECT_SUPERLOCK
    	aktiv
    REMOTE_DOUBLE_SUPERLOCK
    	aktiv
    REMOTE_LAZY_LOCK
    	nicht_aktiv
    SEL_ZV_SENDER
    	nicht_aktiv
    SENSOR_REGEN
    	nicht_aktiv
    SENSOR_SETTLE_TIME
    	r50
    THRESHOLD_STEPPER_MOTOR
    	r50
    TRANSIT_MODE
    	nicht_aktiv
    TRIGGER_DURATION
    	r50
    ULTRASONIC_WINDOW_OPEN
    	aktiv
    VERRIEGELN_MIT_MOTOR_AN
    	nicht_aktiv
    WIN_PINCH_ENABLE_DRIVER
    	nicht_aktiv
    	aktiv
    WINDOW_AUTO_UP_PASS
    	nicht_aktiv
    WINDOW_INCH_AUTO
    	aktiv
    WINDOW_PINCH_ENABLE_PASS
    	nicht_aktiv
    WINDOW_SHORT_DRIVER
    	aktiv
    WINDOW_SHORT_PASS
    	aktiv
    WINDOW_SHORT_RAISE_DELAY
    	r50
    WINDOW_SUNROOF
    	aktiv
    WIPER_BOOT_INHIBIT
    	nicht_aktiv
    WIPER_CAM_DELAY
    	wert_01
    	nicht_aktiv
    WIPER_PROGRAM_WASH_OPTION
    	option_2
    	wert_01
    	wert_01
    	aktiv
    FRONT_FOG_ENABLE
    	aktiv
    HEADLAMP_LEVEL_TYPE
    	lwr_intern
    INERTIA_SW_FITTED
    	nicht_aktiv
    MISLOCK_BEEP_ENABLE
    	nicht_aktiv
    REAR_FOG_ENABLE
    	aktiv
    	aktiv
    AL_AUS_BEI_KL_50
    	aktiv
    	wert_01
    	nicht_aktiv
    	wert_01
    	plus_0ms
    	4
    	7
    AUSSENTEMP_SENSOR
    	aktiv
    BEDIENSTELLE_FT
    	aktiv
    	aktiv
    	nicht_aktiv
    BLINKIMPULS_WARNBLK
    	nicht_aktiv
    	wert_01
    	wert_01
    	1000ms
    	aktiv
    	nicht_aktiv
    	nicht_aktiv
    CODIERUNG_ERFOLGT_0
    	codierung_erfolgt
    CODIERUNG_ERFOLGT_4
    	codierung_erfolgt
    CODIERUNG_ERFOLGT_5
    	codierung_erfolgt
    CODIERUNG_ERFOLGT_6
    	codierung_erfolgt
    CODIERUNG_ERFOLGT_7
    	codierung_erfolgt
    	wert_01
    DRITTE_TASTE_SENDER
    	wert_01
    	aktiv
    EINKLEMMSCH_VORNE
    	nicht_aktiv
    EINSTEIGHILFE
    	nicht_aktiv
    	nicht_aktiv
    EKS_GEDRUECKT/OFFEN
    	wert_01
    	wert_01
    	wert_01
    	nicht_aktiv
    	nicht_aktiv
    FERNBEDIENUNG_1
    	nicht_aktiv
    FERNBEDIENUNG_2
    	nicht_aktiv
    FERNBEDIENUNG_3
    	nicht_aktiv
    FERNBEDIENUNG_4
    	nicht_aktiv
    	wert_01
    	wert_01
    	aktiv
    	wert_01
    FH_HINTEN_TIPP_AUF
    	aktiv
    FH_HINTEN_TIPP_ZU
    	nicht_aktiv
    	nicht_aktiv
    	aktiv
    FH_TIMEOUT
    	8sec
    FL_AUS_BEI_KL_50
    	aktiv
    	aktiv
    FZV_TIMEOUT
    	wert_02
    	wert_01
    HKL_SPERREN_BEI_ZS
    	nicht_aktiv
    	nicht_aktiv
    	wert_01
    	0ms
    	20s
    	ohne_bedingung
    	nicht_aktiv
    IB_EIN_BEI_HKK/HSK
    	aktiv
    	zwei_minuten
    	aktiv
    	aktiv
    KALTUEBERWACHUNG_BL
    	nicht_aktiv
    	nicht_aktiv
    	aktiv
    	aktiv
    	nicht_aktiv
    KEIN_HECKWISCHER
    	mit_heckwischer
    	aktiv
    	nicht_aktiv
    	nicht_aktiv
    KOMFORTOEFFNUNG_CLT
    	nicht_aktiv
    	nicht_aktiv
    	nicht_aktiv
    	aktiv
    	nicht_aktiv
    LAENDERVARIANTE_ECE
    	aktiv
    LAENDERVARIANTE_US
    	nicht_aktiv
    	nicht_aktiv
    	wert_01
    MIT_AHM
    	aktiv
    MIT_MFL
    	nicht_aktiv
    MIT_OPT_ALARM
    	aktiv
    	nicht_aktiv
    	nicht_aktiv
    NSW_AUS_BEI_KL_50
    	aktiv
    OFFENE_FENSTER
    	nicht_aktiv
    OHNE_HRW
    	nicht_aktiv
    	ohne_bestaetigung
    	mit_absenkung
    POTISTELLUNG_IN_77H
    	wert_01
    PWM_ANSTEUERUNG_AL
    	wert_03
    PWM_ANSTEUERUNG_BL
    	wert_01
    	wert_01
    	wert_01
    	wert_01
    PWM_ANSTEUERUNG_IL
    	wert_01
    PWM_ANSTEUERUNG_NSL
    	wert_01
    	wert_01
    	wert_01
    PWM_ANSTEUERUNG_VA
    	wert_01
    	nicht_aktiv
    	aktiv
    	aktiv
    ROVER_FZV_STATT_BMW
    	bmw_fzv
    SCHEIBE_ABSENKZEIT
    	wert_01
    	ohne_eks
    	wert_01
    SCHWELLE_MERHK_KS
    	wert_01
    SCHWELLE_MERHK_OL
    	wert_01
    	stufe_2
    	nicht_aktiv
    	nicht_aktiv
    	aktiv
    	nicht_aktiv
    	16_min
    	nicht_aktiv
    	wert_01
    	wert_01
    	wert_01
    	sofort
    VERZOEGERUNG_SHD_KS
    	sofort
    WARMUEBERWACHUNG_AL
    	aktiv
    WARMUEBERWACHUNG_BL
    	aktiv
    	aktiv
    	aktiv
    	aktiv
    WARMUEBERWACHUNG_FL
    	aktiv
    	aktiv
    	aktiv
    	aktiv
    	aktiv
    	nicht_aktiv
    	nicht_aktiv
    	wert_01
    	keine_vollendung
    	wert_01
    XENON_TEST
    	nicht_aktiv
    XENON_TIME
    	wert_01
    XENON_TIMEOUT
    	wert_01
    	wert_01
    	wert_01
    ZSW_AUS_BEI_KL_50
    	aktiv
    AIRCON
    	aktiv
    ASR_MSR_DSC
    	asr_msr
    COOLING_FANS
    	twospeed
    CRUISE_CONTROL
    	nicht_aktiv
    CVT_HYBRID_MODE
    	nicht_aktiv
    CVT_SIL
    	nicht_aktiv
    ENGINE_TYPE
    	85kw
    KLIMA_INAKTIV_BEI_VOLLGAS
    	nicht_aktiv
    KRAFTSTOFF_ART
    	bleifrei
    MARKET
    	eu4
    TRANSMISSION
    	cvt_step
    ALTERNATOR
    	105a
    MILANSTEUERUNG
    	aktiv
    TRACTION_CONTROL
    	aktiv
    ABSCHALT_GESCHWINDIGKEIT
    	r50
    ABSCHALTMELDUNG
    	nicht_aktiv
    ABSCHALTWEG
    	r50
    ABSTAND_EINBAU_WANDLER
    	r50
    ANFANGSWERT_ECKE_HINTEN
    	100_prozent
    ANFANGSWERT_ECKE_VORN
    	100_prozent
    ANFANGSWERT_MITTE_HINTEN
    	100_prozent
    ANFANGSWERT_MITTE_VORN
    	100_prozent
    ANZAHL_WANDLER
    	4_wandler
    DAUERTON_MESSBEREICH
    	r50
    ECHOSCHWELLWERTE_ECKE_HI
    	r50_4/05
    ECHOSCHWELLWERTE_ECKE_VO
    	r50
    ECHOSCHWELLWERTE_MITTE_HI
    	r50_4/05
    ECHOSCHWELLWERTE_MITTE_VO
    	r50
    EINSCHALT_GESCHWINDIGKEIT
    	r50
    EINSCHALTMELDUNG_BEI_1MAL
    	nicht_aktiv
    EINSCHALTMELDUNG_IMMER
    	nicht_aktiv
    EINSCHALTVERZOEGERUNG
    	aktiv
    MELDUNG_TASTER
    	nicht_aktiv
    MESSBEREICHE_WANDLER
    	r50
    NOTFUNKTION
    	nicht_aktiv
    NUR_EIN_TONGEBER
    	nicht_aktiv
    OFFSET_MESSBEREICH
    	r50
    PDC_AKTIV/DEAKTIV
    	rueckwaertsgang
    PDC_EIN_BEI_KL15
    	nicht_aktiv
    PDC_SCHALTER
    	nicht_aktiv
    RUECKFAHRGONG
    	aktiv
    SKALIERUNG_ECKE_HINTEN
    	0.80
    SKALIERUNG_ECKE_VORN
    	0.65
    SKALIERUNG_MITTE_HINTEN
    	0.80
    SKALIERUNG_MITTE_VORN
    	0.65
    TONGEBER_HINTEN
    	lautsprecher
    TONGEBER_VORN
    	gong
    WEGKENNZAHL
    	r50
    AHK_ABSTAND
    	r50
    ANHAENGERKUPPLUNG
    	nicht_aktiv
    EIS_AUSBLENDEN
    	aktiv
    LAUTSTAERKE_HINTEN
    	wert_06
    LAUTSTAERKE_VORN
    	r50
    MESSBEREICH_HECKKL_ECKE
    	r50
    MESSBEREICH_HECKKL_MITTE
    	r50
    NUR_KL15_BETRIEB
    	aktiv
    ANTI_DROEHN_STELLUNG
    	nicht_aktiv
    AUSSENGEFUEHRTE_SHD
    	aktiv
    EINKLEMMSCH_REVERSIER_SHD
    	kurz
    HECKKLAPPE
    	nicht_aktiv
    HERSTELLER
    	rover
    KOMFORTFUNK_BEREICH_HEB
    	nicht_aktiv
    OPTIMIERTE_SCHLIESSFKT
    	nicht_aktiv
    SCHIEBEHEBEDACH_TIPP_HEB
    	aktiv
    SEITENTUEREN
    	2_tueren
    EEPROM_SHD
    	nicht_aktiv
    EINKLEMMSCH_SHD_HEBEN
    	nicht_aktiv
    EINKLEMMSCH_SHD_ZU
    	aktiv
    PANIC_CLOSE
    	nicht_aktiv
    SCHIEBEHEBEDACH_TIPP_SENK
    	nicht_aktiv
    DACHTYP
    	asd
    DATENSATZ_1
    	nicht_aktiv
    DATENSATZ_2
    	nicht_aktiv
    KLEMMENSTATUS
    	aktiv
    GEARMOMENTREGLER_MAX_HA_2
    	wert_10
    GEARMOMENTREGLER_MIN_HA_2
    	wert_10
    GAL
    	wert_04
    LAENDERVARIANTE_RADIO
    	ece
    RDS-AF_SWITCHING
    	rds_on/af_auto
    TP_FUNKTION
    	tp
    TP_MINIMAL_VOLUME
    	wert_00
    KEY_MEMORY_RADIO
    	nicht_aktiv
    PTY_TABELLE
    	ece
    REG
    	wert_04
    FLC_SCHWELLWERT_SATZ
    	wert_01
    FLC_SCHWELLWERT_SATZ_2
    	wert_01
    FLC_SCHWELLWERT_SATZ_3
    	wert_01
    FLC_SCHWELLWERT_SATZ_4
    	wert_01
    TYP_FRONTSCHEIBE
    	serienscheibe
    WISCHERMOTOR_RSK
    	wert_02
    AUSSENTEMP_BEWERT
    	wert_02
    AUSSENTEMP_VERDECKLAUF
    	wert_01
    BAUREIHE_CVM
    	r52
    BEDIEN_ENTPRELLZAEHLER
    	wert_03
    BTS_BEWERTUNG
    	wert_01
    BTS_KL30_MIN
    	wert_10
    BYTE_3_LI
    	wert_01
    BYTE_4_LI
    	wert_01
    CHECK_BLOCK_0
    	wert_03
    CHECK_BLOCK_1
    	wert_01
    CHECK_BLOCK_2
    	wert_02
    CHECK_BLOCK_3
    	wert_02
    CHECK_BLOCK_4
    	wert_02
    DEBUG_SIGNAL
    	nicht_aktiv
    DRUCKPUMPE_DREHRICHTUNG
    	rpumpea
    FALTDACH_SPEED_LIMIT_EN
    	aktiv
    FEHLER_MOTOR
    	aktiv
    FZG_SPEED_FALTDACH
    	wert_02
    GESCHW_PRUEFUNG
    	wert_02
    GESCHW_VERDECK_AKTIV
    	wert_02
    GESCHWINDIGKEITSINFO
    	aktiv
    HALL_BETRIEBSSPANNUNG
    	wert_01
    HALL_GRENZWERTE
    	wert_01
    HARDTOP_ERKENNUNG
    	nicht_aktiv
    HYSTERESE_KL_30
    	wert_04
    HYSTERESE_KL_30_UEBER
    	wert_04
    KBUS_FUNKTION
    	aktiv
    KOMFORTOEFFNUNG_VERDECK
    	aktiv
    KONTAKT_ENTPRELLZAEHLER
    	wert_02
    LED_ANSCHLUSS
    	led1
    LOGIK_HARDTOP
    	low_aktiv
    LOGIK_SWBUNT
    	low_aktiv
    LOGIK_V_RESERVE
    	low_aktiv
    LOGIK_VABGEL
    	low_aktiv
    LOGIK_VERDECK_OEFFNEN
    	low_aktiv
    LOGIK_VERDECK_SCHLIESSEN
    	low_aktiv
    LOGIK_VSW41
    	low_aktiv
    LOGIK_VSW42
    	low_aktiv
    LOGIK_VVORNE
    	low_aktiv
    POWER_ON_RESET
    	nicht_aktiv
    POWERDOWN_ZEIT
    	wert_01
    RAM_CHECK
    	aktiv
    ROM_CHECK
    	aktiv
    SFR_ZUGRIFF
    	nicht_aktiv
    TO_ENTR_FALTDACH
    	wert_03
    TO_VERDECK_AUFFAHREN
    	wert_03
    TO_VERDECK_ZUFAHREN
    	wert_03
    TO_ZEIT_ABL_HS
    	wert_03
    TO_ZEIT_ANH_HS
    	wert_03
    TO_ZEIT_WLM
    	wert_03
    UEBERSPANNUNG_KL_30
    	wert_09
    UNTERSPANNUNG_KL_30
    	wert_09
    VKBODEN_ERKENNUNG
    	aktiv
    VPUMPE_FEHLER
    	aktiv
    WARTEN_SCHEIBEN_ABGESENK
    	aktiv
    WINDLAUF_DREHRICHTUNG
    	mw1
    ZEIT_BEDIENTASTER
    	wert_02
    ZEIT_BIS_BEDIENFEHLER
    	wert_01
    DELAY_BEIM_ABLEGEN
    	wert_03
    DELAY_VOR_VERRIEGELN
    	wert_03
    A_TEMP_DELTA_OFFSET
    	wert_01
    A_TEMP_OFFSET_SCHWELLE
    	wert_01
    AKUSTIK_TANK_RESERVE
    	nicht_aktiv
    AKUSTIK_WARN_UEB_LEITUNG
    	nicht_aktiv
    AKUSTIK_WARN_UEBER_BUS
    	aktiv
    AUSSENTEMP_DELTA_K2
    	wert_01
    AUSSENTEMP_SPERRZEIT_2
    	wert_01
    AUSSENTEMP_SPERRZEIT_3
    	wert_01
    AUSSENTEMP_ZEITKONST_Z3
    	wert_01
    AUSSENTEMP_ZEITKONST_Z4
    	wert_01
    BC_ANGEZEIGTE_GESCHW
    	wie_tacho
    BC_GESCHW_ANZEIGE_DIGITAL
    	aktiv
    BC_TWSZ_2
    	nicht_aktiv
    BREMSFLUESS_FILTER_ZEIT
    	25_sec
    BREMSFLUESSIGKEIT_UEBER
    	can_bus
    GONG_FREQ2
    	wert_01
    KALIBRIERUNG_WEGSTRECKE
    	wert_01
    KOMBI_TYP
    	ece
    KUEHLMITTELTEMP_WARNSCHW
    	wert_01
    MOTORHAUBE_OFFEN_WARNUNG
    	aktiv
    ODOMETER_OFFSET
    	wert_01
    PREDRIVE_CHECK
    	aktiv
    RUECKWAERTSGANG_WARNUNG
    	nicht_aktiv
    SCHWELLE_DZM_WARNFELD_1
    	nicht_aktiv
    SCHWELLE_DZM_WARNFELD_2
    	aktiv
    SCHWELLE_DZM_WARNFELD_3
    	aktiv
    SCHWELLE_DZM_WARNFELD_4
    	aktiv
    SIA_LITER_ZAEHLER
    	1.6_cooper_auto
    SIA_TAG_ZAEHLER
    	wert_01
    STOPPUHR_0_AUF_100
    	nicht_aktiv
    STOPPUHR_1/4_MEILE
    	nicht_aktiv
    TANK_1_ADC_FEHLER_OG
    	wert_01
    TANK_1_ADC_FEHLER_UG
    	wert_01
    TANK_2_ADC_FEHLER_OG
    	wert_01
    TANK_2_ADC_FEHLER_UG
    	wert_01
    TANK_FEHLER_SCHWELLE
    	wert_01
    TANK_SCHW_RES_HYSTERESE
    	wert_02
    TANKDAEMPFUNG_FAHRT_AB
    	wert_01
    TANKDAEMPFUNG_FAHRT_AUF
    	wert_01
    TANKDAEMPFUNG_NORMAL_AB
    	wert_01
    TANKDAEMPFUNG_NORMAL_AUF
    	wert_01
    TANKGEBER_1_LITER
    	kennlinie_02
    TANKGEBER_1_WIDERSTAND
    	kennlinie_02
    TANKGEBER_2_LITER
    	kennlinie_02
    TANKGEBER_2_WIDERSTAND
    	kennlinie_02
    TLETZ
    	wert_01
    UEBERTEMP_WARNUNG
    	nicht_aktiv
    VERBRAUCH_2
    	nicht_aktiv
    VES_INFO
    	r50
    WARN_GESCHW_LIMIT
    	nicht_aktiv
    ZEITINSP_DISPLAY_FLAG
    	icon_wird_nicht_angezeigt
    ZEITINSPEKTION
    	aktiv
    ZEITINSPEKTION_VORGEZOGEN
    	aktiv
    ANZEIGE_CFC
    	nicht_aktiv
    AUSGABE_FEHLERSPEICHER
    	aktiv
    BC_ANZ_NACH_ATEMP_WARN
    	aktiv
    BC_QUITT_ATEMP_WARN_LSS
    	aktiv
    CC_AUSSENTEMPERATUR
    	aktiv
    DWS_UEBER
    	can_bus
    TANK_NICHT_MESSBAR_OBEN
    	wert_02
    BC_NAVI_VISUELLE_WARNUNG
    	nicht_aktiv
    BC_RW_VERB_U_GRENZE
    	wert_01
    SIA_GWSZ_BEI_SERVICE_LSB
    	wert_01
    SIA_GWSZ_BEI_SERVICE_MSB
    	wert_01
    SIA_INSPECTION_COUNTER
    	wert_01
    SIA_LITER_BEI_SERVICE
    	wert_01
    SIA_TAGE_BEI_SERVICE
    	wert_01
    SIA_TIME_SERVICE_COUNTER
    	wert_01
    TANKDAEMPFUNG_STAND_AB
    	wert_01
    TANKDAEMPFUNG_STAND_AUF
    	wert_01
    BC_AKTUELLER_VERBRAUCH
    	aktiv
    BC_DURCHSCH_GESCHW
    	wie_tacho
    BC_GESCHW_ANZEIGE_GESCHW
    	wie_tacho
    BC_GESCHW_ANZEIGE_KBUS
    	nicht_aktiv
    BC_LIMIT_GESCHW
    	wie_tacho
    BREMSBELAGVERSCHL_WARN
    	aktiv
    MOTOR_OELSTAND_AUSWERTEN
    	nicht_aktiv
    UHR
    	aktiv
    ANZAHL_STUFEN
    	wert_03
    GERAETENAME
    	wert_01
    KMH_HYSTERESE
    	wert_02
    KMH_STUFEN
    	wert_03
    NACHLAUFZEIT
    	wert_03
    SPRACHERKENNUNG_EIN_AUS
    	nicht_aktiv
    ULF_EIN_AUS
    	aktiv
    KBUS_SPEED_LOWERLIMIT
    	lower_limit
    KBUS_SPEED_UPPERLIMIT
    	upper_limit
    KUEHLMITTELTEMP_BEGRENZ
    	aktiv
    KUEHLMITTELTEMP_SPERRZEIT
    	wert_01
    OILPRESSURE_ANZEIGEWI
    	kennlinie_01
    OILPRESSURE_WERT
    	kennlinie_01
    OILTEMP_ANZEIGEWI
    	kennlinie_01
    OILTEMP_WERT
    	kennlinie_01
    SEATBELT_PASSENGER
    	nicht_aktiv
    SEATBELT_US
    	nicht_aktiv
    SRS_VIA_KBUS_WARNUNG
    	nicht_aktiv
    KS_ABSCHALTUNG_AL
    	nicht_aktiv
    KS_ABSCHALTUNG_BL
    	aktiv
    	nicht_aktiv
    	aktiv
    	aktiv
    KS_ABSCHALTUNG_FL
    	nicht_aktiv
    KS_ABSCHALTUNG_IB
    	aktiv
    KS_ABSCHALTUNG_KRB
    	nicht_aktiv
    KS_ABSCHALTUNG_KZL
    	nicht_aktiv
    KS_ABSCHALTUNG_NSL
    	aktiv
    KS_ABSCHALTUNG_NSW
    	nicht_aktiv
    KS_ABSCHALTUNG_SL_H
    	nicht_aktiv
    KS_ABSCHALTUNG_SL_I
    	nicht_aktiv
    KS_ABSCHALTUNG_VA
    	aktiv
    KS_ABSCHALTUNG_ZSW
    	nicht_aktiv
    DECREMENTIER_PAUSE
    	wert_02
    HAUPTALARM_PUMPE
    	wert_02
    PAUSE_PUMPE
    	wert_02
    ALARM_MUW_SENSOR
    	nicht_aktiv
    	nicht_aktiv
    	nicht_aktiv
    	nicht_aktiv
    	nicht_aktiv
    LWR_POS2
    	wert_03
    LWR_POSR
    	wert_03
    	nicht_aktiv
    MIT_NSL_RECHTS
    	nicht_aktiv
    PWM_ANSTEUERUNG_IB2
    	wert_01
    WARM_WITH_OL_BTS716
    	nicht_aktiv
    	nicht_aktiv
    ZENTRAL_FH_SCHALTER
    	nicht_aktiv
    	wert_02
    DWS_NEW_SPEC
    	aktiv
    DWS_US
    	nicht_aktiv
    BLS_POLL_TIME
    	wert_02
    	nicht_aktiv
    AWL_1
    	nicht_aktiv
    AWL_2
    	nicht_aktiv
    CC_GURTWARNUNG_1
    	nicht_aktiv
    CC_GURTWARNUNG_2
    	nicht_aktiv
    CRASHPARAMETER_1
    	r50
    CRASHPARAMETER_10
    	r50
    CRASHPARAMETER_16
    	r50
    CRASHPARAMETER_17
    	r50
    CRASHPARAMETER_18
    	r50
    CRASHPARAMETER_19
    	r50
    CRASHPARAMETER_1A
    	r50
    CRASHPARAMETER_2
    	r50
    CRASHPARAMETER_3
    	r50
    CRASHPARAMETER_4
    	r50
    CRASHPARAMETER_5
    	r50
    CRASHPARAMETER_6
    	r50
    CRASHPARAMETER_7
    	r50
    CRASHPARAMETER_8
    	r50
    CRASHPARAMETER_9
    	r50
    CRASHPARAMETER_A
    	r50
    CRASHPARAMETER_B
    	r50
    CRASHPARAMETER_C
    	r50
    CRASHPARAMETER_D
    	r50
    CRASHPARAMETER_E
    	r50
    CRASHPARAMETER_F
    	r50
    CURTAIN_BEIFAHRER_1
    	nicht_aktiv
    CURTAIN_BEIFAHRER_2
    	nicht_aktiv
    CURTAIN_FAHRER_1
    	nicht_aktiv
    CURTAIN_FAHRER_2
    	nicht_aktiv
    EAM_TIMEDELAY1
    	r50
    EAM_TIMEDELAY2
    	r50
    GURTKONTAKT_BEIFAHRER_1
    	aktiv
    GURTKONTAKT_BEIFAHRER_2
    	aktiv
    GURTKONTAKT_FAHRER_1
    	aktiv
    GURTKONTAKT_FAHRER_2
    	aktiv
    GURTKONTAKT_FONDLINKS_1
    	nicht_aktiv
    GURTKONTAKT_FONDLINKS_2
    	nicht_aktiv
    GURTKONTAKT_FONDRECHTS_1
    	nicht_aktiv
    GURTKONTAKT_FONDRECHTS_2
    	nicht_aktiv
    GURTSTRAFFER_FONDLINKS_1
    	nicht_aktiv
    GURTSTRAFFER_FONDLINKS_2
    	nicht_aktiv
    GURTSTRAFFER_FONDRECHTS_1
    	nicht_aktiv
    GURTSTRAFFER_FONDRECHTS_2
    	nicht_aktiv
    GURTSTRAMM_SEITENCRASH_1
    	nicht_aktiv
    ITS_GEGENUEBER_1
    	nicht_aktiv
    ITS_SCHRAEGCRASH_1
    	nicht_aktiv
    KNIEBAG_BEIFAHRER_1
    	nicht_aktiv
    KNIEBAG_BEIFAHRER_2
    	nicht_aktiv
    KNIEBAG_FAHRER_1
    	nicht_aktiv
    KNIEBAG_FAHRER_2
    	nicht_aktiv
    LANGER_CURTAIN_1
    	its
    MRSA_TUERE_1
    	aktiv
    MRSA_TUERE_2
    	aktiv
    OC3_1
    	aktiv
    OC3_2
    	aktiv
    POL_1
    	aktiv
    POL_2
    	aktiv
    POS_1
    	nicht_aktiv
    POS_2
    	nicht_aktiv
    POSI_1
    	nicht_aktiv
    POSI_2
    	nicht_aktiv
    ROLLOVER_OPTION_1
    	nicht_aktiv
    ROLLOVER_OPTION_2
    	nicht_aktiv
    SBE1_1
    	nicht_aktiv
    SBE1_2
    	nicht_aktiv
    SBR_BEIFAHRER_1
    	nicht_aktiv
    SBR_BEIFAHRER_2
    	nicht_aktiv
    SBR_FAHRER_1
    	nicht_aktiv
    SBR_FAHRER_2
    	nicht_aktiv
    SLV_BEIFAHRER_1
    	nicht_aktiv
    SLV_BEIFAHRER_2
    	nicht_aktiv
    SLV_FAHRER_1
    	nicht_aktiv
    SLV_FAHRER_2
    	nicht_aktiv
    UPFRONT_LINKS_1
    	aktiv
    UPFRONT_LINKS_2
    	aktiv
    UPFRONT_RECHTS_1
    	aktiv
    UPFRONT_RECHTS_2
    	aktiv
    US_SCHWELLEN_1
    	aktiv
    GURTSTRAMM_SEITENCRASH_2
    	nicht_aktiv
    ITS_GEGENUEBER_2
    	nicht_aktiv
    ITS_SCHRAEGCRASH_2
    	nicht_aktiv
    LANGER_CURTAIN_2
    	its
    US_SCHWELLEN_2
    	aktiv
    GATEWAY_ST_VERBR_KON
    	nicht_aktiv
    SBE_STEP_DOWN
    	wert_01
    SBE_STEP_UP
    	wert_01
    SBE_THRESHOLD
    	wert_01
    FLC_FAILSAFE
    	nicht_aktiv
    FLC_OHNE_RLS
    	nicht_aktiv
    MIT_FLC
    	nicht_aktiv
    MIT_FLC_SCHALTER
    	nicht_aktiv
    MIT_WWA
    	aktiv
    	wert_01
    	wert_01
    	wert_02
    DSP_1
    	r50
    DSP_2
    	r50
    DSP_3
    	r50
    DSP_4
    	r50
    AIRBAG_SG_VARIANTE
    	mrsz4
    GURTWARNUNG_KBUS
    SBR_BEIFAHRER
    	nicht_aktiv
    SBR_FAHRER
    	nicht_aktiv
    ANLIEFERKODIERUNG
    	nicht_aktiv
    KALTUEB_AUS_BEI_SCG
    	aktiv
    	wert_01
    	wert_01
    	nicht_aktiv
    TILT_SIRENE
    	aktiv
    TM_ENTR_HECKKLAPPE
    	aktiv
    WWA_LED_KL15_DAUER
    	wert_01
    WWA_LED_MOT_DAUER
    	wert_01
    WWA_LED_TAKT_AUS
    	wert_01
    WWA_LED_TAKT_EIN
    	wert_01
    WWA_LED_TRIG_DAUER
    	nicht_aktiv
    WWA_LED_WASCH_DAUER
    	wert_01
    CRASHPARAMETER_1B
    	r50
    CRASHPARAMETER_1C
    	r50
    GK/OC3/POL_1
    	nicht_aktiv
    GK/OC3/POL_2
    	nicht_aktiv
    GURT_NICHT_AB_GK_1
    	nicht_aktiv
    GURT_NICHT_AB_GK_2
    	nicht_aktiv
    AKUSTIK_PAUSE
    	wert_01
    BATTMON_SPGABFALL_FZG
    	wert_01
    BATTMON_SPGSCHWELLE
    	wert_01
    BATTMON_STARTVERZ
    	wert_01
    UHR_KBUS
    	nicht_aktiv
    BACKUP_DESTINATION_ADDRES
    	wert_03
    BACKUP_SMSC_ADDRESS
    	wert_03
    DEF_DESTINATION_ADDRESS
    	wert_03
    DEFAULT_SMSC_ADDRESS
    	wert_03
    HOTLINE_ADDRESS
    	wert_01
    TM_FOLLOW_ME_HOME
    	nicht_aktiv
    TM_POSLIGHT
    	nicht_aktiv
    ANZEIGE_POSITION_AUS
    	nicht_aktiv
    FUHRPARK_FLOTTENMODUS
    	nicht_aktiv
    DSP_CDC_DIGITALLTG
    	wert_00
    ATC_EIN_AUS
    	aktiv
    SYNCML_EIN_AUS
    	aktiv
    ABL_VER_SW5_VERKN
    	verknuepft
    CHECK_MOTOR_LAUEFT
    	motor_muss_n_laufen
    FEHLERZEIT_ABL_VERR
    	wert_02
    HUT_SPANNB_ERKENNUNG
    	aktiv
    LOGIK_ABL_VERR
    	low_aktiv
    LOGIK_HUT_SPANNBUEGEL
    	low_aktiv
    NO_OPEN_ABL_VER_ERR
    	gesperrt
    TO_ZEIT_ABL_VER
    	wert_02
    ZEIT_FUER_STOPP_ABL_VER
    	wert_02
    ZEIT_ZW_ABL_VERR_HYDR
    	wert_02
    FEHLER_RENTRIE
    	aktiv
    FUNKTIONSBIT01
    	nicht_aktiv
    FUNKTIONSBIT02
    	nicht_aktiv
    FUNKTIONSBIT03
    	nicht_aktiv
    FUNKTIONSBIT04
    	nicht_aktiv
    FUNKTIONSBIT05
    	nicht_aktiv
    PARAMETERBYTE01
    	wert_01
    PARAMETERBYTE02
    	wert_01
    PARAMETERBYTE03
    	wert_01
    PARAMETERBYTE04
    	wert_01
    PARAMETERBYTE05
    	wert_01
    TO_ZEIT_ABL_VER_OEFF
    	wert_02
    AUTOM_ER_KEY_OFF
    	nicht_aktiv
    EXT_BEREICH_KURZHUB
    	wert_01
    	aktiv
    MAXWERT_FH_POS_HB
    	wert_01
    MAXWERT_FH_POS_LB
    	wert_01
    DWS_AUSFALL_BLINKZEIT
    	nicht_aktiv
    VERDECK_OFFEN_WARNUNG
    	nicht_aktiv
    BLOCK_SIZE
    	default
    DL_DELAY
    	default
    EMPTY_STOP_LIMIT
    	default
    PBAP_EIN_AUS
    	nicht_aktiv
    SMS_EIN_AUS
    	nicht_aktiv
    AUX_IN
    	kein_aux
    TV_SYSTEM
    	wert_01
    KALIBRIERUNG_TACHO_RIP
    	wert_01
    MEKKA_INDIKATOR
    	aktiv
    CRASHPARAMETER_1D
    	r50
    EAM_TIMEDELAY3
    	r50
    EAM_TIMEDELAY4
    	r50
    scotland clydebank
    why do you not stop playing with expert tools this is like vcds you do not change coding or parameters without taking back up learn to walk before you can run you can do serious damage with dealers tools if no knowledge of what you are doing .
    Oct 2017
    Quote Originally Posted by godfathertre View Post
    you are perfectly right. fun fact is that I always make backup of everything, but not this time. What I'm trying to do right now is make the key for remote work again and never touch this stuff anymore!
