hello mate, I have a board in the bank this can be done?
or is this only done through obd2?
the car is far away the client just thought about bringing me the cluster.
I will take pictures. I would like to see someone has pin out
WINNER THE LOSER
Oh that's very interesting. I did not want to buy such OBD2 tools, because of fear of destroying some ECUs in the cars. But if it's also possible to just connect the instrument, I have to think about that again.
Do you know if they all (dp4, smelecom, carprog, vvdi) have this function, or of which one do you know that? Or is it no special function, just startup instrument and connect to CAN Lines from instrument instead of OBD/Gateway pins?
Pinout of the tucson instrument is 16-, 39+, 40+, if 1 is top left.
display shows mileage that way
Why are you afraid of destroying other ECU?, When the OBD tool accessing the Instrument cluster from OBD port, it is only loaded the Bootloader file to the RAM of a cluster and it will not harm other ECU connected from the OBD port.
The same when you accesing the Airbag module from the OBD port, it was only loaded Bootloader to the airbag Module the same to the other Module, so it is safe because when the Loader dosnt match to the Module to access, it will not connect and the tool will displayed cannot connect or cumminication error
By the way, any cluster that can access via diagnostic port can do on the bench, even the the car is not present, just look for its CAN line, K line or MBUS depending on year of car
pongsky (23rd January, 2018)
problems by obd2...
modify the km but now the needles stopped working ...
Any idea how to repair this?
someone has a file to write with upa?
WINNER THE LOSER
here is a file read in bank after adjustment of the board by obd2...............
could they help me in repairing it or a file in good conditions
Thanks in advance
WINNER THE LOSER
