Golf 7
from 2014 and up for the moment only Continental/VDO instrument clusters are supported
Golf 7
Next week will realise new update of passthru drivers.
Hello ,
first car and first failure
try to add spare key for GOLF7 VDO-MQB 2014 keylessGo , connection to dash ok , connection to server...... , and after few second i get error message ( cannot release SA2 code..... )
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
I used key from set
dooshan (21st January, 2018)
Sa2 is seed key is for entering bootmode i think.. ..
topclef (21st January, 2018)
secret key, seed key, service key , secret service ......
no matter for me how he call them , for me it doesn't worked
The most probable reason for not being able to do the job is that the Golf VI on which you've worked might not be produced after 07.2014.
On the website there is a compatibility matrix and there is written that the supported Golf VI are the ones produced after 07.2014 and with a Continental VDO Dashboard.
Please check if it is produced after 07.2014, otherwise you won't be able to program the key.
Regards,
Kris
ventzy (23rd January, 2018)
Just want to ask if it took abrites 4 years of development of MQB why Vvdi is having same functions for MQB?
Thanks.
Sent from my SM-G935F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
ps80l (21st January, 2018)
For change mileage Renault Laguna III 2012 with AVDIi , can i do full only of OBD ? or i need to remove dash and ABS ?
