Results 1 to 8 of 8
    Default Corsa D 13283819 Error B1000 - Replace ECU help please
    Please help me with Airbag Corsa D Temic
    13283819
    Error B1000- -Replace ECU
    Dump 95160 in attachment
    Best Regards
    Darek
  2. The Following User Says Thank You to MatygaD For This Useful Post:
    rolcke (3rd August, 2022)
  3. #2
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by MatygaD View Post
    13283819
    Best Regards
    Darek
    Your Clear File :
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  4. The Following 3 Users Say Thank You to CarCity For This Useful Post:
    elekcars (16th March, 2023), MatygaD (24th January, 2018), saratea (14th July, 2021)
  5. #3
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Try this, but I think hardware problem ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
  6. #4
    Quote Originally Posted by CarCity View Post
    Your Clear File :
    Thanks.
    File woirking but in first byte must have 00 not FF
    With FF crash data is stored
    Best Regards
    Darek
  7. The Following User Says Thank You to MatygaD For This Useful Post:
    immokill (11th April, 2019)
  8. #5
    Oct 2018
    Milano Italy
    Hallo. I have the same problem. I made a clear file from my crash but remain the error b1000.
    I don't have the password to see your file. I upload my clear file, Can someone can tell me why this error is active?
  9. #6
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Did you try to disconect battery . I erase with. Opcom2018 this error and remove battery with clear file . And FF is first bytes
    Here to HELP!
  10. The Following User Says Thank You to immokill For This Useful Post:
    VIMA46 (11th April, 2019)
  11. #7
    Oct 2018
    Milano Italy
    In other 2 clear file from the same ECU i have 00 on the first byte and then i leave this. I have tried to disconnect battery, but not with the last version of my file, now i retry to disconnect.
  12. #8
    Oct 2010
    EU
    Hello all,
    i have the same airbag unit and same problem, B1000-replace ECU. Carprog can not clear this.
    Please can you help me with tested solution?
    Temic 13283819 327963935
    Opel Corsa D Z10XEP 11.2009
    eeprom 95160
    many thanks in advance.
