Results 1 to 9 of 9
    Top Poster mack0r's Avatar
    Mar 2017
    Default Seat Leon edc15p EGR off
    Hello. I need EGR off without dtc. I have plate egr And dtc.
    Can i do EGR close in hysteresys map? 55E0C, 55E60 And seconds blocks?
    chipdanix's Avatar
    Apr 2016
    Poland - Warsaw
    Nobody one knows everything we learn a lifetime
    repair ecu , dtc , dpf , egr ..........
  3. The Following 2 Users Say Thank You to chipdanix For This Useful Post:
    mack0r (30th January, 2018), pike (30th January, 2018)
    Mar 2017
    In forum i read this metod is wrong. Good solution is hysteresys like edc16 or switch. Hmm
    I close two hysteresys in two Banks And test tomorrow. When i get dtc i write file with EGR maps full (8500) And test
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    in VAG edc15p for egr totally close you can do home with simple tools and not more errors and nothing
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    Mar 2017
    my friend has blinded egr and has dtc. I turned off EGR on hysteresis and see if it will be ok.
    AVDigitale's Avatar
    Apr 2017
    now is blinded limp mode or not,you like to remove software now both mechanic and sof
    File Service
    Mar 2017
    mechanically EGR stays, is only blinded and they are dtc without limp. today I will check if hysteresis solve the problem.
    Mar 2017
    I wrote and without dtc for now. probably EGR off by the hysteresis works correctly
  10. #9
    AVDigitale's Avatar
    Apr 2017
    good job
    File Service
