Page 10 of 15 FirstFirst ... 56789101112131415 LastLast
Results 136 to 150 of 218
  1. #136
    camelgd's Avatar
    Jan 2011
    South Illinois
    2012 Fusion would not connect.
  2. #137
    camelgd's Avatar
    Jan 2011
    South Illinois
    2003 Ford Ranger AKL added one key at a time, no 10 minute.
    2014 F150 added key
  3. #138
    Oct 2018
    Europe
    Anyone using this tool in europe region, with particular interest for ford and psa cars?
  4. #139
    Jan 2017
    USA ����
    2004 ford mustang AKL USA h72
    AUTEK ikey820
    erase keys, key number, and parameter reset options only DOES NOT HAVE ADD A KEY FAIL
    OBDSTAR keymaster DP
    erase keys and key number options only DOES NOT HAVE ADD A KEY FAIL
    CK200!!!!!!!!!!!
    erase keys, key number and ADD ONE KEY
    CK200 SUCCESS IN 10 MINUTES
    im telling you this thing is still kicking ass many years later
    keymaster DP fully up to date 5/2019
    ikey820 fully up to date 4/2019
    CK200 hasnt been updated since late 2016 yet can do things they cant
  5. The Following User Says Thank You to sleepyrz For This Useful Post:
    thug252 (7th May, 2019)
  6. #140
    Jan 2012
    N.Y. U.S.A.
    2015 Toyota Corolla "H" chip
    Add Key OK.
    2004 Nissan Pathfinder
    Add key OK, no pin needed.
  7. #141
    Jan 2018
    CA, USA
    tried today
    2005 altima, communication fail,
    2002 chrysler sebring - communication fail
    2009 altima - made 2 keys no problem.
    im new to making keys on anything but BMWS. i bought ikey820 to just make keys for friends and family, just to learn more on other vehicles. now strangely the two vehicles that had communication issues both cars just randomly stopped working so they asked me if i can make they a key thinking its a key issue, could this be a coincidence ikey didnt connect both cars or possibly a ECU issue? being these were vehicles of someone i know, i didn't do much diagnostic and it was more of a favor than a job so after trying other years and models and the ikey not working i gave up, figure ill learn more do some research before i waste time.
  8. #142
    Jan 2017
    USA ����
    2003 mitsubishi eclipse AKL USA
    lishi trunk and cut key(door is broken)
    IKEY820
    and in the mitsubishi eclipse there seems to be no key programming at all?? for 02 03 04 05 only remote programming no key programming FAILURE WTF IS THIS CRAP!!!!!!!!!!
    i tried some other years/models and it wouldnt communicate at all.........
    x300DP
    this had the same problem really not communicating or wouldnt program or whatever tried many options FAILURE
    CK200
    plug in and select by model and year
    there are two types
    type 1 no comms
    type 2 goes straight in to key programming and supplies the correct pincode and car is programmed in 30 seconds SUCCESS
    ck200 still winning
    kinda sad though right?
  9. #143
    camelgd's Avatar
    Jan 2011
    South Illinois
    Just curious- did you try Chrysler version of Mitsubishi like under Sebring? I don't know if the programming is there or not, might be worth a try on the next one.
  10. The Following User Says Thank You to camelgd For This Useful Post:
    sleepyrz (4th June, 2019)
  11. #144
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    Hey all! Anyone have any luck with AKL Toyota H key? I keep getting error “init file failed” “error code 1:1D” “error code 2:20”.
    Any help greatly appreciated! I have updated and activated token.
  12. #145
    Sep 2016
    Wanted to add one car I haven't seen in these post. For American user :
    Saturn Astra ( not sure exactly what kind of Opel Astra this one is )
    Using the Opel menu
    Read PIN from radio.
    Programmed remote head key.
    --Success
    Sent from my Redmi Note 7 using Tapatalk
  13. #146
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by cniksor View Post
    tried today
    the nissan is possible its a bcm issue. the tool usually does these no problem.
    The sebring is more likely user error how ever you can not use this tool to pull the PIN anyway unless its the coupe model. Which model sebring is it? sedan, coupe or convertible?
  14. #147
    Jan 2018
    CA, USA
    Quote Originally Posted by narkeleptk View Post
    it was sebring coupe, but i find out vehicle worked perfect then it was in accident, after repairs car no longer started, so i think something is not connected during repair. so possible no issue with ikey820.
  15. #148
    Jan 2017
    USA ����
    2008 Ford expedition all
    Ikey820 selected by model/year
    add key in 10 seconds success
  16. #149
    Jun 2017
    US
    Cadi Cts 2013, no option for this year. 2014 wouldn't work. Had to OBP a spare which I should have done to begin with but that no drivers door lock thing on these models threw me off. Have to use the trunk lock.
  17. #150
    Jan 2017
    USA ����
    2002 taurus add key
    5 seconds SUCCESS
    2005 ford excursion erase all and add keys work just fine
    10 minute wait SUCCESS
