Hey Friends!
someone cleared
immo box Opel Vectra C
does anyone have a file with motoroloi HC05B6 Mask 0F10V
09 131 781 HC Siemens 5WK4 763
Thank you for your help
Hey Friends!
someone cleared
Maybe Vectra B, but not Vectra C. Vectra C uses CIM. Maybe your best solution is immo off but that depends on the ECU. Send ECU part No.
Cheers!
yes this is Vectra B 1999 year
Your file from vectra B,but best solution is immo off in ecu.
thank you buddy
is the possibility of Immo Off in ECU Delco
CPCY 09364599 HSFI-C
I can only read flash kessem
I also have an ECU read from carprog
Can you do immo off?
you can't do immo off in that ECU!
...this is immo1 you can see pin in dump and program old keys, also make sync with ECU without any problems, I do that with op-com...
gpmoto2 (7th February, 2018)
I have programmed the keys
but I do not want to do synchro ECU Op-com
Go to ECU ->programming or special function -> program immobilizer and click activate, you don't need to wait the button come active, it's done.
What year is the car? What is the ECU type?Maybe it is immo 2, then you will need security codes for both immo and ECU.
You will need tech2 if you want to have immo or just remove it.
Reality of life :
1:Never argue with an idiot, he will drag you down to his level and beat you with experience
2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
3:Jealousy is a sign of inferiority
4:Everyone lies
How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
If you like to read garbage, don't slow down, just speed up
