hi guys. need swap damaged fizicaly and shorted mcu motorola fried out. win module-ignition switch chyrsler 2010 fobik.
if anyone had experiece please write in pm.
thanks in advance
thanks in advance
It's pretty simple if it's a new WIN. It's pin will be 0000 and you'll be prompted to write a new pin then the VIN. After that the pcm will transfer seed data to the new WIN, program keys and you're done. If you can't get the original pin from the old WIN, it would be a good idea to get it from a dealer just to keep things stock. If you can't, post the VIN and I'll try to get it for you.
drugowaz (14th February, 2018)
by what part number look for replacement DAMAGE WIN MODULE and maybe what alternative part numbers fit?
car is 2010 voyager usa market
mine are part numbers are
P05026872AE
TKJ2080E0111
5WK49093
433.92MHZ
Usa Newer chryslers also have 433
I was told its from usa but need confirm.
Not important i think
Just looking about part numbers
update its diesel euro.
