    Ireland
    Default 2008 Kia Sorento 2.5 Auto transmission wiring diagram needed
    Would anyone have a wiring diagram for the Automatic gearbox for a 2008 Kia Sorento?
    I have a shift solenoid fault and need to check wiring from gearbox to transmission ECU.
    there are some very good wiring diagrams for this vehicle under Mitchell on demand,
    the transmission is in two parts unfortunately you can't copy these.
  3. The Following User Says Thank You to autotrans For This Useful Post:
    sherl645 (21st February, 2018)
    Ireland
    I don't have that program but thanks anyway..
    Sent from my ONEPLUS A3003 using Tapatalk
    if you let me know the shift solenoids involved I can give you the ECU pin numbers.
    Ireland
    That would be great thanks, it has fault p0773 which I think is shift solenoid E or LC/B solenoid.
    Thanks..
    hope this helps
  8. The Following User Says Thank You to autotrans For This Useful Post:
    sherl645 (24th February, 2018)
