Results 1 to 7 of 7
Thread: bosch kts 520
    Mar 2009
    Default bosch kts 520
    hi - do anyone know were i can buy a diagnostic cable for bosch kts 520. ? the obd cable between interface and car
    Quote Originally Posted by crayzee View Post
    you search for this one??
    I found on ebay.de
    OBD OBD2 Kabel Diagnoseleitung f?r BOSCH KTS bei eBay.de: Mess- Pr?ftechnik (endet 08.11.09 20:31:38 MEZ)
    regards
    manchuu
    Has anyone seen an adapter for OBD2 to the round adapter?
    Thank you,
    Newbie dimosbmw's Avatar
    Mar 2009
    GREECE
    Default Bosch kts cables
    What kind of cable are you looking for exactly?? you have ubox 1 and you want to buy ubox 2, you have no cable? pls be more specific so i can help you. Take a look of thsese: Bosch UBOX 02 for KTS 520,550 and 650 on eBay (end time 11-Nov-09 20:00:47 GMT) only ubox 2 to replace it if you have ubox 1 or the full cable here: Bosch OBD can Cable with UBOX02 for KTS 520,550 & 650. on eBay (end time 22-Nov-09 12:12:57 GMT).
    I wiss i helped you out!
    That looks like a CAN adapter. I am looking for the pre-OBD2 connector. Before 1995.
    Mar 2009
    Hello
    What car do you need the cable for???.If it is a pre 95 vehicle then you are probably looking at a vehicle specific connector.According to my understanding obd2 is a standard socket that all manufacturers use and obd or carb socket is vehicle specific.I hope this helps you out as I am also looking for vehicle specific connectors for the kts!!!
    Mar 2009
    GREECE
    I think that you ask for the first picture cable..
    but this one have only 4 pins to connect and you should use 3 cables at least: 1.from kts interface to obd 2. from obd to universal 3.from universal to car adapter cable.
    or you can use only the 2 first cables by making you own connections between universal cable and vehicle's diagnostic soscket by using universal electrical adaptors(many time till you connect the cables)
    And.. there is another problem: some cars like Mitsubishi lancer '92 need some extra cables (uni 1 blue , uni 2 blue/white) and these cables aren't available at the first cable.
    So the best solution is another universal cable which contains uni1 and uni2 and its connect direct to the intherface (no use of obd cable) The cable's code is 1 684 465 488 (second picture)
