Results 1 to 7 of 7
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Default Help with DTC+DPF Volvo V50 EDC16c34
    Hi people,
    I read with BDM this volvo V50 1.6d 109hp with ecu EDC16c34 from year 2007.
    The DPF is psychical removed on exhaust and car is in limp mode.
    I removed the DPF, now car is not in limp mode, but the fault and DTC is not gone.
    I think DPF switch need to off or DTC remove.
    Who can help me with this?
    I attached DPF removed file here.
    DTC fault codes are:
    2A30
    2A40
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    johak's Avatar
    here one solution
  3. The Following User Says Thank You to johak For This Useful Post:
    sdtsedat (22nd February, 2018)
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Thank you! You also removed DTC's? Because there is fault in instrument cluster (engine workshop fault in dpf)
    Sedat Garip
    Belgium
    With Kind Regards,
    johak's Avatar
    yes, i deleted some dtcs including these 2
  6. The Following User Says Thank You to johak For This Useful Post:
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Thank you my friend.
    I thanked and give you REP.
    I try it tommorrow when customer is back and let you know. Very strange, i did these car's with my solution and all was ok but these not.
    The good one is car is no more in limp mode.
    I give feedback
    Sedat Garip
    Belgium
    With Kind Regards,
  8. The Following User Says Thank You to sdtsedat For This Useful Post:
    johak (22nd February, 2018)
  9. #6
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    Default hi
    try this mate without chks is the file calculate chks before write and report
    pass in PM!
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  10. #7
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Update: All oke. No more DTC's or fault in dashboard!
    Very thanks.
    Regards from Belgium
    Sedat Garip
    Belgium
    With Kind Regards,
