Results 1 to 15 of 15
    kostas's Avatar
    Jan 2009
    macedonia is greek
    Default Renault Megane 1.4 16V immo off help please
    Hello friends
    I have the ecu from reno megane 1.6 16V 99model with AC
    S110030018 D 8200020950 7700110471
    Can you help me to remove the immo please??
    My original dump from 29F200AB
    Regards!!!
    rafal's Avatar
    UK - PL
    ................enjoy............
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following 3 Users Say Thank You to rafal For This Useful Post:
    ganm55 (30th May, 2022), kostas (24th February, 2018)
    kostas's Avatar
    Jan 2009
    macedonia is greek
    thanks ok...
    Jan 2013
    need help with immo off sirius 32 megane 1.4 16v with ac
    antwnhszr's Avatar
    macedonia is greek....
    Quote Originally Posted by fytfh View Post
    cars for trash m8....cut pin 58 before plugin...
  7. The Following User Says Thank You to antwnhszr For This Useful Post:
    fytfh (13th March, 2018)
  8. #6
    Jan 2013
    Quote Originally Posted by antwnhszr View Post
    this solution work?
  9. #7
    Jan 2013
    The car not start with this file
  10. #8
    dodge69's Avatar
    Mar 2012
    Belarus
    Default Immo off
    keep each other in three variants and do not forget to disconnect 58 contacts before installing the computer. As a result, let me know the password in my personal message
    thank you if I helpedgratitude motivates me to help further
  11. The Following User Says Thank You to dodge69 For This Useful Post:
    fytfh (14th March, 2018)
  12. #9
    rafal's Avatar
    UK - PL
    Quote Originally Posted by dodge69 View Post
    держите друг друга в трех вариантах и ​​не забудьте отключить 58 контактов перед установкой компьютера. В результате дайте мне знать пароль в моем личном сообщении.
    Only English language please
    need help
    who will help?
  13. The Following User Says Thank You to rafal For This Useful Post:
  14. #10
    Jan 2013
    keep each other in three variants and do not forget to disconnect 58 contacts before installing the computer. As a result, let me know the password in my personal message.
    have tested all solution but still dont start
  15. #11
    Jan 2013
    car is 1.4 energy 8v
  16. #12
    dodge69's Avatar
    Mar 2012
    Belarus
    Syrius 32 and 34 controllers have a flash 29f200 or 29f400. Immo records are in addresses from 4000 to 7FFF. If these cells are filled with FF, the driver will be new to the configuration. If in these areas we find the values ​​of 64 C7 in several places and only fill them, FF is a driver's walk without immo, sometimes you need to remove two more cells in front of them. In syrius 34, you sometimes need to additionally add the rice to the code string, because otherwise it will not match the air conditioner.
  17. The Following User Says Thank You to dodge69 For This Useful Post:
    danielif (30th May, 2022)
  18. #13
    dodge69's Avatar
    Mar 2012
    Belarus
    try this option
  19. The Following User Says Thank You to dodge69 For This Useful Post:
    Ermakbrat (21st November, 2018)
  20. #14
    Apr 2013
    thanks ok passs
  21. #15
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Post your file
