Results 1 to 15 of 19
    Nov 2015
    Question Volvo V70 2000 does not start. Message: "Start prevented Try again".
    Hello, dear DK users and professionals.
    First of all, the car has lost all keys. Tried to recover the CEM image. Now CEM says there are 3 keys and sees the key inserted. Volvo syncro tool says that syncro bytes are all in place, but when trying to start the car, the message "Start prevented try again" is displayed. I am missing something.
    Also attached 2 Volvo Vida screenshots that may help to locate the problem.
    CEM+ECM dumps are attached. Any advice, help needed, please.
    Regards, Alex
    Jul 2015
    USA
    ECM E2 readout does not look right to me. See attached
    Nov 2015
    I have read this with 2 different devices, Orange5 and Minipro TL866. The result was exactly the same. I have been told, that things go much harder and that codecard utilite does not help in my situation. Now looking for the information about wheither can Tango OEM do Volvo keys or not.
    Jul 2015
    USA
    I believe Tango can do keys. I need some done as well so may be time to purchase...
    Nov 2015
    Original Tango does these keys no doubt. Nobody confirmed OEM (chinese version) does them so far.
  6. The Following User Says Thank You to gljuk For This Useful Post:
    hpsyndicate (19th March, 2018)
    Nov 2015
    May i ask you for help. I am attaching two files. CEM image from other car with valid keys and the engine eeprom from the car that does not start. We just need to make car move, so i ask somebody to help with modifying ECU eeprom to sync the ECU to the CEM.
    Thank you!!!
    Tango OEM identification keys pictures
    Nov 2015
    I have no Tango. Sorry. Is it possible, to write syncro to ECU without Tango?
  10. #9
    MartiLer's Avatar
    Dec 2016
    Yes. need a programmer to read meg48.
  11. #10
    Nov 2015
    The last image of CEM is actually a combination of original car's vin and configuration part and immo part of working car. I am doing it for the first time and actually, i have no plans to do it again. Next time i will buy the service from good level specialist. But this time i thougt we can manage with taking working cem with valid immo and put to other car and sync the ecu.
    So post nr.6 CEM has three keys inside, just need to put the syncro to motor's eeprom. Do i still need Tango? I could only afford chinese OEM version of Tango. I could never pay off the original Tango price.
  12. #11
    synchro orginal post look ok , if not crank key bad ,show reading key id48
  13. #12
    Default volvo synchro
    tray this synchro eprom
  14. The Following User Says Thank You to janusz21 For This Useful Post:
    gljuk (1st April, 2018)
  15. #13
    Nov 2015
    Thank you very much!!!
    I will let it a try and then report. I can not promise I will do it fast, bcause the car is some miles away from me. Sorry for that.
  16. #14
    soxten's Avatar
    Mar 2013
    Program a used cem to virgin and then reload by Volvo Vida online.
    Skickat från min iPhone med Tapatalk
  17. #15
    Nov 2015
    You started Do the virgin dumps differ one from each other? There are so many 1999-2004 CEMs that are with different part numbers. How can i find virgin dump if there are so many different versions?
