Results 1 to 4 of 4
    In EEP
    Default Peugeot ATE ABS MK70 no communication
    Hi i have here one Peugeot with ATE ABS MK70 with no communication can me everybody litle help with this trouble thanks
    Apr 2016
    holland
    Posted in ABS, Audi, Citroen, Daihatsu, Ford, Mazda, Nissan, Peugeot, Renault, Seat, Skoda, Suzuki, Toyota, Vauxhall / Opel, Volkswagen
    The Teves MK70 (ATE) ABS unit is fitted to a wide range of modern vehicles and has similar design flaws as the earlier Teves MK60 ATE ABS pump. Both units have internally built pressure sensors with a low maximum pressure rating and have identical common failures as you can see below:Common Teves MK70 ATE ABS Pump Problems:
    • Brake Pressure Sensor (G201)
    • ESP / ASR / TCS / DCS (Traction) Light On
    • ABS Light On
    • No Communication Fault
    • Wheel Speed Sensor Fault
    • there are manny companies how repair !!!
    • google ATE ABS MK70 no communication and you will find companny that will repair for you
  3. The Following User Says Thank You to schouten1977 For This Useful Post:
    vasa (1st March, 2018)
    In EEP
    Quote Originally Posted by schouten1977 View Post
    • ABS Light On
    ok not problem Sreach on google company for repair ..........i go find solution thanks
    Mar 2018
    montpellier
    maxi fuse or ecu abs is KO
