Hi all,
I'm having a problem with a 2015 Volvo xc60. I changed the mileage, but when i put the ignition back on it jumps back to the original mileage. Has anyone had this problem before?
Any help would be appreciated.
Hi all,
would be nice to know which tool you used.
you need to block synchro with cem
I tried using enigma first then tried with smok and i also unplugged the front doors to see if that would work but it still bounced back.
Nicolas9 (4th March, 2018)
I have totally same problem on xc60... I purchase xtool to do this job because they said that it will work... But it did not, I also done millage in door modules, But km Jumps back, because sw in not working... I tried more than 10 cars and none of them worked.... Now they claim that it works in this new year update, But ~~~~ this Update is 600 eur and I just bought it last year for 600 because of volvo and it did not work,...
So I am interested if someone can disable dash-cem synchro in flash?
pcbox (7th August, 2020)
Yes Kermol says that it works in 2018 verson and say me that he can do it if I sendhim flash... I sent him flash a lot of times and newer get answer... I can not belive taht I actually throw away last year because he advertised how it is working.
So I please someone with x tool or any tool if he can read original flash and flash after it is blocked synchro- after millage change. I only need to do 2 cars and I not want to buy update from x-tool because I bought it last year... Better to buy smok than, it seems more okay
only safe way is can blocker i was try programming with all tool same story....have rool back mileage on one yolvo after one year
Where can get this can blocker?
bugarcek (5th March, 2018)
please change your signature. it hurts my eyes
I searched for can blocker on engimatool site but Volvo is not listed. Can I use any can blocker? I looked for that gecko can but volvo is not listed
But if I understand the situaton correctly.
Smok, x-tool only block synchro dash->cem this block is done in car cluster...
So if I have flash readen from this car, the only thing which I need is to change few bytes and flash and km will stay on cluster.
Problem here is because noone does not know what to change or maybe do not want to share.
