    i_shot_the_sheriff's Avatar
    Nov 2008
    Default Jaguar X-Type 2.5 gasoline 2005 model Security Failed
    Hello mates
    I have this X-Type that has Security Failed on dash and no crank at all !
    With Autel i don't see any DTC related to Immo. I have tried Focom and Ford VCM but no communication with this car...
    I have taken cluster out and read 9S12 and i see that keys are programmed ok !
    So i guess that the synchronization between ecu and Cluster is broken...! Can someone make synchro on this car?
    Ecu has 2 x 93c86 and cluster has 9S12 mcu inside. Can someone help please ?
    Thanks in advance
    Nov 2008
    Anyone pleaseeee???
    brend's Avatar
    Oct 2015
    Same where
    For swap need JLR or any tool where have same sulution for ecu swap.
    Nov 2013
    the other side
    i had 1 yesterday , same issue
    i used maxisys and learned immo back in special functions
    worked like a boss
    Nov 2008
    I have tried this function friend...! But I keep on getting the "security access failed" on my Maxisys....
    Sent from my SM-G930F using Tapatalk
    Nov 2008
    I have updates on the matter....
    I have the Jaguar Sdd diagnostic on my store now..... I have reprogrammed the immo but still same thing. Security failed and I keep on getting code B2301 code 12 saying about antenna not connected!
    I have tried another antenna and check3d the wiring from the antenna to the cluster but all ok ! Any suggestions on what to do ?
    I'm going crazy with this one ....
  7. The Following User Says Thank You to i_shot_the_sheriff For This Useful Post:
    dany3459 (27th January, 2023)
