Results 1 to 15 of 23
    Feb 2017
    Northants, GB
    Default Jaguar S Type Stereo Code.
    Hi guys. Struggling to get the code from this Jaguar S type unit. Jaguar P/N 2R83-18B876-AC. Serial JACC2020214049
    Please see attached dump. I get code 1421 but this doesn't work. no sure what im doing wrong. Any help would be much appreciated.
    Cheers - kam
    smoggy's Avatar
    Apr 2009
    UK North East
    try code 1421
    EDIT: sorry I see you already had code
  3. The Following 3 Users Say Thank You to smoggy For This Useful Post:
    Albert G (11th March, 2018), bogege (11th March, 2018), things4u2get (11th March, 2018)
    Bulgaria
    If the unit is codelocked it will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
    Code Entry as Follows:
    Switch Radio On - Display Shows
    " CODE "
    Enter CODE in the order it is read - eg:
    For Example, To Enter Code 1234
    Press Preset 1 then 2 then 3 then 4
    The Code will Enter Itself Automatically
  5. The Following 5 Users Say Thank You to bogege For This Useful Post:
    Albert G (11th March, 2018), masterskay62 (11th March, 2018), shooting (11th March, 2018), smoggy (11th March, 2018), things4u2get (11th March, 2018)
  6. #4
    Feb 2017
    Northants, GB
    Hi guys, thanks for your quick reply's. No unit is not locked yet but on last attempt. Not sure if there is some type of hash check or algorithm in extracting the code, logically 1421 should work. Inside was factory fresh and un-tampered.
    Bulgaria
    You try in the car!
    Or try to change address 160.2.5.8 -07 to 00 or 01
  8. The Following 3 Users Say Thank You to bogege For This Useful Post:
    masterskay62 (11th March, 2018), smoggy (11th March, 2018), things4u2get (11th March, 2018)
  9. #6
    WALES
    Quote Originally Posted by things4u2get View Post
    Is it IN the car or on the bench?
    wbr
  10. The Following 2 Users Say Thank You to shooting For This Useful Post:
  11. #7
    Feb 2017
    Northants, GB
    Hi thanks for your reply. It's on the bench. Cheers kam
  12. #8
    WALES
    Just put it IN the car
    wbr
  13. The Following User Says Thank You to shooting For This Useful Post:
  14. #9
    Feb 2017
    Northants, GB
    Hi shooting. No the unit came from a breakers yard. Are you thinking it's immo or can bus enabled? Regards kam
  15. #10
    WALES
    No, it'll be a power issue..
    wbr
  16. The Following User Says Thank You to shooting For This Useful Post:
  17. #11
    Feb 2017
    Northants, GB
    Hi. How come? It powers on and I can key in the code in but the code is just incorrect. cd ejects fine. Sorry maby I wasn't clear in my opening thread. Cheers kam
  18. #12
    Jun 2017
    Italy now...
    JACC2020214049=1421
  19. The Following User Says Thank You to Juliano31 For This Useful Post:
  20. #13
    WALES
    It shows like it's working but if not all the power is provided it won't accept code
    Code is 100% correct
    wbr
  21. The Following 4 Users Say Thank You to shooting For This Useful Post:
    bogege (11th March, 2018), Hashim1 (23rd June, 2024), Logann (25th November, 2023), things4u2get (11th March, 2018)
  22. #14
    Feb 2017
    Northants, GB
    Ok cheers guys ill double check my bench psu / pinouts and let you know how i get on.
  23. #15
    WALES
    Also if ampage is too low, just put it IN the car......
    wbr
  24. The Following User Says Thank You to shooting For This Useful Post:
