I have a CH341A programmer. Is it possible to read and write content of the 95160 eeprom in order to do immo off ? I guess in version 1.29 of the programmer software reading of the 95160 should be possible but I am not sure.
The answer is: It works. You have to install firmware version 1.30 and choose 25LC160.
drfiat (17th April, 2018)
Tried yesterday but no luck. Do i have to remove the chip because i tried with clamp. I tried on AIRBAG module 95160WQ chip.
Reality of life :
1:Never argue with an idiot, he will drag you down to his level and beat you with experience
2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
3:Jealousy is a sign of inferiority
4:Everyone lies
How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
If you like to read garbage, don't slow down, just speed up
jovanzac (25th July, 2018)
Bumping this old thread with corrections, since Google finds this thread.
You can use 95xxx , but you must 5 volt-mod the CH341A. Just add a jumper between 3.3V and 5V. Black edition: that's the two pins closest to the 25xx printed diagram. The 3.3V regulator does not blow up from this.
You can also use 93xxx chips, but you need to do a simple wire mod. See this video https://www.youtube.com/watch?v=hPKckby54uA
Then use NeoProgrammer 2.2.0.10 or AsProgrammer 2.1.0.13 (tested versions)
These apps have 93xxx and 95xxx chips already listed.
I did desolder the 95160 chip. I don't know if this is necessary.
