Results 1 to 4 of 4
    Question Reading vag immo pin and turn immo off via OBD?
    Hello I am looking for software that will read immo pin from ecu over obd and also read and write to turn immo on and off via obd.Is there any software like that out there??I heard vag eeprom should do it but I can't get it to read ecu.
    Mar 2018
    Quote Originally Posted by AudiS4 View Post
    There is a software called VAG Tacho K+CAN that will do exactly this, if you have the proper cable.
    A quick search for "VAG Tacho" on your favorite major search engine will return a website where the software is available for free from the developer (freeware/fully legal) and the appropriate drivers/manuals/etc.
    Please let me know if this works for you or not, either way. Good luck.
    EDIT: See enclosed TXT file attachment for link
    Quote Originally Posted by redivivus View Post
    Ok I have KKL usb cable or do I need the dedicated dongle???
    Mar 2018
    Sorry I haven't been online recently.
    I believe you only need the dongle for programming keys, but I could be mistaken. As far as I know, VAG TACHO uses a common K+CAN USB cable. Also, I recommend searching your favorite major Chinese wholesaler website for "Your IMMO + OBD" or "EDC16" or "Your ECU + OBD". I recently found something called a "Drive Box" which claims to disable IMMO on VW/AUDI, and the cost is low enough that I am going to order it just to try it out for myself, and if it works, it will get added to my toolbox for future customers!
