Results 1 to 9 of 9
    Top Poster ramiz auto lock's Avatar
    Nov 2017
    NORTH LONDON
    Default Audi a6 steering lock esl repair
    Hi to all dk friends
    I have a 2005 audi a6 in garage today that has problem with esl .
    Turn key in ignition but no lights on dash no start and no noise from esl.
    I cleard the fault codes then boom lights on dash and car start no problem .
    I see on ebay there is some repair kits for a6 esl and i am trying to rwpair it.
    I was wondering if some one had done this job before and is it hard to do or is there any thing that i need to be aware of ?
    Basically looking to hear from someone that experienced this before
    Any help will be appreciated.
    Sent from my SM-G925F using Tapatalk
    Jan 2016
    No problem to solder repair kit but be very careful with screws holding metal cover of ELV. Killed one by punching to much with little hammer to unscrew them
  3. The Following User Says Thank You to amigokola For This Useful Post:
    ramiz auto lock (22nd March, 2018)
    Nov 2017
    NORTH LONDON
    Quote Originally Posted by amigokola View Post
    Will do thanks.
    So it should not be hard after removing the esl...
    Jan 2016
    Not at all. Just one relay and few microswitches as I remember. Only legs soldered to ground are little hard to desolder...
    wissamshaat's Avatar
    Oct 2017
    france
    when elv is open cut the red black wire and u will never have to worry about it
    but steering will not lock againe
  7. The Following 10 Users Say Thank You to wissamshaat For This Useful Post:
    alclot (8th January, 2020), cipijoint (23rd October, 2019), Danielsach (17th May, 2018), HeXeN (21st December, 2018), lovinedi03 (8th May, 2021), ramiz auto lock (23rd March, 2018), rm23 (12th July, 2020), yugo45 (23rd March, 2018), _estima_ (9th March, 2019)
  8. #6
    Apr 2013
    United Kingdom
    I get the steering lock to unlock when i put key in ignition switch, then i cut power red and black wire, but i still dont get ignition after turning key.
    I noticed that when the remote locking function on key stops working, i cannot find kessy in vag scan.
    Can this still be caused by faulty switches and relay in esl
    Hit like and thanks if I've helped you!!
  9. #7
    ricked's Avatar
    Apr 2016
    Europe
    2 out of 10 can be repaired this way other 8 have MCU problems and is dying
    also no problems with de-soldering if you use enough heat...
  10. #8
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by urcarpc View Post
    Probably you have fualty microswitch/es in the EIS module, check for it.
    Just use dremel to make a cut on screws and then unscrew them with a flat head screwdriver
  11. #9
    Aug 2018
    East Pole
    Better than that esl work for nothing... is this: replace the key reader. With a working one from scrapyard and you will start the car. Come back and post that i was right
  12. The Following User Says Thank You to volorucinski For This Useful Post:
    immoneard (14th July, 2020)
