Results 1 to 12 of 12
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default opel astra h mt35e 1.6xep big problem not solve 1 week
    hello members
    i have serios problem with this car
    i start car and 5-10 min run ok ...motor turn off....not have starter and not connect with ecu
    after 5-10min start again ..all ground points ok power supply to ecu ok can ok
    i learn 3 ecu's and same problem...
    when car turn off throttle valve crazy and sound krkrkrkrkrkrkrkrkrkrrkr
    sim module errors:u2100-00 can-bus high speed,u2105 can-bus with ecu.
    abs errors
    u2105 can with ecu,u2139 can with sim and u2100 can-bus high speed
    ecu show multiple errors
    p0201 injector 1 malfunction
    p0202 injector 2 malfunction
    p0203 injector 3 malfunction
    p0204 injector 4 malfunction
    p0230 fuel pump primary circuit low
    p0650-ipc massage range
    P1600-3A replace ecu
    U2103 can bus no communication
    crankshaft sensor ok ,camshaft sensor ok,throttle valve ok.
    anyone can help with this F...k problem
  2. The Following User Says Thank You to vasko For This Useful Post:
    Stelaras26 (15th January, 2022)
  3. #2
    dimitar's Avatar
    I had same problem with astra g
    Replaced everything
    In the end turned out that some fool put spark plugs without resistor causing ecu resets..........
    Replaced spark plugs problem solved
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  4. The Following User Says Thank You to dimitar For This Useful Post:
    cosminaec (24th March, 2020)
  5. #3
    DUPNICA BULGARIA
    Turi 4itavi swe6ti ili vij da ne ti iskri bobinata.
  6. #4
    keturi's Avatar
    Oct 2010
    Lievatu
    Have had the same problem for 2 weeks Lift up engine ECU from engine ground, place on the rubber or paper(isolate) and connect lead from ECU ground to the battery ground, if car starts OK and throttle body keep quied, replace starter motor. 99%
    Quote Originally Posted by vasko View Post
    hello members
    abs errors
  7. The Following 3 Users Say Thank You to keturi For This Useful Post:
    Faraday (25th March, 2018), majster10 (18th January, 2024), Stelaras26 (15th January, 2022)
  8. #5
    autobo's Avatar
    May 2014
    Bulgaria
    I have before the same problem,and solved after replacing starter motor.
  9. #6
    Mar 2013
    It is possible for starter to remain engaged and cause problems when car is running ?
    Same car ,same DTCs .After lot of reading on the web could be :-
    -coil
    -ground cables
    -faulty CIM
    On my case car stops while is put in 1st gear ,sometimes does not start in the morning but every time must wait at least 10 sec before cranking again .
    I am pretty sure that starter can give a lot of interference via supply lines which will lock the ECM ,but I have doubt that a bad starter will cause problems if the engine is already running .
    For a non starting issue this page offer a complete analysis
    https://www.gmto.nl/new/nl/ta/11/ope...laat-niet-aan/
  10. The Following User Says Thank You to TR0UBLESH00TER For This Useful Post:
    MOBILTRONIC (16th May, 2019)
  11. #7
    Mar 2017
    romania
    REPLACE STARTER.....In my case Astra H z16xep easytronic....cranks 2 sec then fuel gauge goes down and engine check light disapear from cluster...OPCOM says NO COMMUNICATION WITH ECU...after clear all communication error try to crank...after to 2sec same issue...check every thing a hundred times....8 DAYS WORK ..at the last i installed a new STARTER...ENGINE STARTS ...REVS OK...NO COMM ERRORS....EVERYTHING OK.....
    I think that the old starter thru the positive 12v feed brings interference in ECUs...
    REPLACE THE CRAZY STARTER
  12. The Following User Says Thank You to marian2019 For This Useful Post:
  13. #8
    Aug 2018
    East Pole
    Mostly, spark coils solve the missfire and p1600 issues.
  14. The Following User Says Thank You to volorucinski For This Useful Post:
  15. #9
    italy
    hi i had a case on opel astra with mt35e ecu.
    i replace ignition coil, starter, ecu but i had problem again.
    sometimes car didn't start, starter run half second and after i've not comunication with ecu,fuel indicator goes down and trottle body goes crazy.
    after few minutes ( wait can goes in sleep mode, or removed ecu fused) i was going in comunication with ecu again and fuel indicators goes up.
    in this case i replace positive line from battery to fuse box, and car it hasn't been back from 2 years.
  16. #10
    italy
    but today i've a different case.
    in ecu it's stored only p1600 intermittent.
    and car sometimes turns off wile it's drived.
    i don't want to replace more parts as last time,
    someone have experience for this case?
  17. The Following User Says Thank You to fra69 For This Useful Post:
  18. #11
    Apr 2018
    I have the same case as vasko first post.
    Change ECU and add mass "-" to ecu from battery and engine start.
    edit:
    I had another such case later and replacing the ecu + ignition coil helped
  19. The Following User Says Thank You to kamaz007 For This Useful Post:
  20. #12
    Apr 2025
    Hello Vasko, did you resolved the problem and what was it?
